starter problem?
Old Nov 24, 2011 | 05:14 PM
londonking's Avatar
londonking
Default starter problem?
My bike won't start. Turns over very slowly, 2 or 3 times then I stop because battery is just about dead. I've done a load test on battery and it's strong. Battery is good. So I cleaned terminals, put a volt meter and tried turning it over again. Got the same result, no go. Volt meter dropped from 12.52 to 7.43 volts when I pushed the start button and cranked 2 or 3 times. Do I need a new starter or is it something else? Any input would be greatly appreciated. Thanks.
Old Mar 8, 2024 | 10:35 PM
Moses110's Avatar
Moses110
2-3 sec. crank on good battery shouldn't drop below 9v. Isolate battery from bike and load test Results should revile batt. issue or bike issue. Battery most likely needs replaced. Edit oops, old thread, could still be helpful to some.
Old Mar 16, 2024 | 06:07 PM
ironmike666's Avatar
ironmike666
i would say battery. Just went thru this with my bike. Replaced relay, got starter rebuilt, changed plug wires…. No change. Replaced battery(it tested good btw/was under 1 year old, HD battery) started cranking over to beat hell. Still wouldnt start, replaced plugs and 👍🏻
so even if your battery is showing ok, it may indeed be crap.
Old Mar 16, 2024 | 07:12 PM
Rounders's Avatar
Rounders
Put a jump pack on it, and see if it starts. Put a charger on high for few minutes, and see if it tries harder to start, if so for either battery.
To bad 13 years ago he did not return and tell us what the issue was.
Maybe message and ask.
Old Mar 16, 2024 | 08:18 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Hopefully @londonking got it solved after 13 years. Maybe he traded the bike, I don't know. Just wondering.
Looks like nobody answered his post in a timely fashion.
Old Mar 17, 2024 | 08:52 AM
bustert's Avatar
bustert
probably using the same battery
Old Mar 17, 2024 | 10:43 AM
CoolBreeze3646
I have heard you can get 20 years out of a battery.
LDB187
Feb 21, 2017 06:52 PM
big-bad-wolf
Jul 11, 2014 05:24 AM
martinez_nc
Feb 23, 2013 02:35 PM
texashillcountry
EVO
36
Mar 21, 2012 09:55 PM
elect.glide
Electrical/Lighting/Alarm
Nov 20, 2008 06:45 PM
