Help!!!!!
Old Mar 24, 2012 | 07:57 PM
Colwyn's Avatar
Colwyn
Stage III
Default Help!!!!!
I ride a 06 streetbob, riding to work the other morning turned into the entrance and the Harley cut out, restarted but cut out after a few seconds, let the bike cool off for a few hours tried to restart, turning over ok but not starting, checked all the fuses all ok then I noticed the system relay was ticking and Dynojet power comander was flickering. Checked the diagnostics and got under S u1255 u1097 and u1016 under SP u1016 U1255 and u1064. Checked and replaced both relays, tried my friends speedo because some of the diag codes make reference to the speedo, checked the harness plugs for corrosion but all seems to be ok. At the moment the system ticks occasionally and still no spark at the plugs, Has anybody had this problem? any ideas what to check next?
Old Mar 24, 2012 | 08:55 PM
scotty3's Avatar
scotty3
Unplug the power commander and see if bike starts.........might also be a dead TSM or TSSM
Clear the error codes and see which ones come back
Old Mar 25, 2012 | 02:27 AM
Colwyn's Avatar
Colwyn
Stage III
Hi thanks for the reply I tried as you suggested unplugging the power comander still not starting, cleared the codes tried restarting checked codes same ones appear if it is the tsm or tssm how do I check to find out which has gone because both a pretty expensive
Old Mar 25, 2012 | 03:33 AM
scotty3's Avatar
scotty3
Well you only have a TSSM or a TSM you don't have both
Do you have a security fob ? If not then you only have a TSM if you do then you have a TSSM
Old Mar 25, 2012 | 03:53 AM
Colwyn's Avatar
Colwyn
Stage III
Yes I have got a security fob but what baffles me is that I just ridden 12 miles and then it just dies. When I push the button on the fob the alarm seems to arm and disarm ok. How do I check the TSSM?
Old Mar 25, 2012 | 02:46 PM
scotty3's Avatar
scotty3
Below is a link to the Speedo, TSM-TSSM & ECM Diagnostics for a 2005 Dyna which should be the same for the 2006
http://www.box.com/s/1397ac7717c313aeebb7
steelerdude1
May 7, 2019 06:19 PM
ElColchon
Electrical/Lighting/Alarm
Sep 18, 2015 08:23 PM
glider69
May 22, 2014 11:02 AM
RussH
Sep 1, 2013 03:24 PM
yota
Aug 21, 2005 07:00 PM
