P0261 p0263 p1002 codes
Python 2-1 exhaust
screamin Eagle intake with K&N filter
PCIII with Generic map
I've got the following codes:
P0261 Front Injector Open/Low EFI
P0263 Rear Injector Open/Low EFI
P1002 System relay Coil High/Shorted EFI
I have already changed out all the fuses as well as both relays. Battery is new.
I had some coughing and sputtering problems but bike ran...till it stalled and wouldn't start.
Towed it home and installed new battery and fueses and relays.
Now bike will fire, but stalles after a few seconds.
I can hear the fuel pump kicking on and off.
There was corrosion on the fuses and relays, but couldn't really get in there to clean it out..installed new fuses and relays with dielectric grease.
ANY IDEAS?
Python 2-1 exhaust
ANY IDEAS?
