2012 Electrical Problems?
Old Jun 16, 2012 | 05:00 PM
apopj's Avatar
apopj
Default 2012 Electrical Problems?
Hello all,
Today, while riding with the group, my check engine light and battery light both came on. A quick check showed charge voltage at 11 Volts. It normally shows 16, and I was told 16 is normal.
I immediately returned home, not knowing if it would restart should I shut it down. I noticed on the ride home that the charge voltage would drop to about 10 volts, slowly build to 14, the idiot lights would go off and it would hang at 14 for a few minutes. Then, the voltage would drop, the lights would come on and remain that way for several minutes, when the whole process would start over.
I heard that Harley was aware of the problem but weren't sure how they were going to handle it. Has anyone else had this problem or know anything about it?
thanks,
Jeff
Old Jun 16, 2012 | 06:02 PM
desertrat702's Avatar
desertrat702
there is a service bulletin to replace the voltage regulator based on its date of manufacture. you can go to the hd website and register with your vin, it will tell you if the bulletin applies to you
wjg
Electrical/Lighting/Alarm
Sep 18, 2017 04:22 PM
lost_in_calgary
Nov 12, 2013 08:50 PM
MSGTUSMC
Aug 5, 2013 02:09 AM
Airborne350G
May 27, 2012 01:55 AM
Streetrunner
Aug 23, 2009 08:06 AM
