No brake light
Old Sep 11, 2012 | 04:57 PM
Fatboy SaL's Avatar
Fatboy SaL
3rd Gear
Default No brake light
I have a 2010 fatboy lo I changed the rear fender last night and now no brake light. I have the peneca led rear tail light with the signals n brake flasher which has worked fine for 2 years I used all the oem stock wiring and harness please help!
Old Sep 11, 2012 | 05:12 PM
RANGER73's Avatar
RANGER73
You either snapped a wire on the light printed circuit board or under the fender
Old Sep 11, 2012 | 05:17 PM
Fatboy SaL's Avatar
Fatboy SaL
3rd Gear
Circuit board is good even tried the stock incandescent no luck I will check under the fender thanks
Old Sep 11, 2012 | 11:29 PM
Fatboy SaL's Avatar
Fatboy SaL
3rd Gear
Default Brake light
Nothing under the fender everything good any ideas
Old Sep 12, 2012 | 12:16 AM
"Dead Broke"'s Avatar
"Dead Broke"
Does the front brake lever still make the brake light come on? And the rear brake pedal nothing?
Old Sep 12, 2012 | 12:39 AM
PSJBrock's Avatar
PSJBrock
6th Gear
might have shorted out the brake light switch
Old Sep 12, 2012 | 07:13 AM
Fatboy SaL's Avatar
Fatboy SaL
3rd Gear
Neither front or rear brake works I don't think I shorted both brake light switches
Old Sep 12, 2012 | 09:01 AM
UltraNutZ's Avatar
UltraNutZ
i'm making the assumption that you had to remove the connectors from the wiring to get the fender off. If so I would go back to the connector and make sure all wiring is in the correct slots and properly seated in the connector
Old Sep 12, 2012 | 06:42 PM
RANGER73's Avatar
RANGER73
There's a Molex connector under the seat that joins the front and rear brake light switches. then goes to the rear brake light. Check there.
Mishyn
Jul 23, 2015 07:54 PM
Fatboy SaL
Electrical/Lighting/Alarm
Sep 12, 2012 07:43 AM
agent58
Mar 2, 2008 09:51 AM
earl b
Mar 1, 2008 08:56 AM
CRYPTO4952
Mar 15, 2007 12:31 AM
