normal/hyper-speed turn signals
Old Sep 24, 2012 | 05:09 PM
deuceriderusa's Avatar
deuceriderusa
Default normal/hyper-speed turn signals
Hi all, I'm new on the forum. The issue I'm dealing with is a left turn signal on my 04 Deuce which flashes as it should most of the time. Then for whatever reason, when I activate the switch, it flashes normally about 5 or six times then takes off into hyper-speed mode. If I manually cancel it and reactivate, it's fine again. The bulbs are good. I've cleaned the contact points on them and also the sockets. I coated everything with dielectric lube. Works great for a few days and then starts again. Any suggestions would be appreciated. Thanks.
Gil935
Mar 30, 2016 07:26 PM
Reindeer
11
Sep 27, 2012 06:34 AM
Rancid17
Jun 23, 2012 08:43 PM
budgar
Jun 9, 2011 03:16 PM
aztecfatboy
General Topics/Tech Tips
Nov 24, 2009 12:56 PM
