PC111
Old Jan 28, 2007 | 09:22 PM
ultra2006's Avatar
ultra2006
Default PC111
Ok, another HD Tech telling me how bad the PC111 is and now if I go into the mountians, that my ECM will not adjust to the alitude, as it is over ridden by the fix map in the power commander, someone help me out here, any suggestions ori is this, Truth or Fiction. Thanks
Old Jan 28, 2007 | 09:31 PM
nvsteve's Avatar
nvsteve
Default RE: PC111
Fiction. The ECM still does it's job. The PC just alters the signals it receives from the ECM.
I would guess the HD tech was trying to sell you on a SERT which certainly is a godd option.
Old Jan 28, 2007 | 10:55 PM
ultra2006's Avatar
ultra2006
Default RE: PC111
Yes he wanted to sell the download for 150 bucks, thanks glad to know that the ECM will still adjust for the alituide.
Old Jan 29, 2007 | 12:30 AM
Rhubarb's Avatar
Rhubarb
Default RE: PC111
PCIII only modifies the signal sent to the injectors by the ecu. It changes it based on the settings you put in. It doesn't override, just adds or removes by a percentage based upon the map you configure. All electronics work as normal.
stevefxdi
Apr 10, 2011 09:56 PM
Kbore
Exhaust System Topics
May 22, 2010 12:53 PM
lejj909
Sep 13, 2008 03:24 PM
sloth
Jan 7, 2008 07:25 AM
2StrongHayn
Sep 18, 2007 11:10 AM
