DIY Flash programming stock EFI
i am really sad you never get to your end goal, but i would really like to work with you on some other subjects as you look like you have the skill. my approach to this is different. 1 method is frowned upon so i wont discuss it here. the other method is i actually reverse the actual firmware of the ECM to extract the seed/key algorithm. this is the first time i am touching harley but have worked on many new vehicles immobilizer, dashboard and ecu algorithms from the oldest to the last across all makes and models. besides the ecm i am after the BCM algorithms as well. did you ever open any BCM to see what processor is inside ?
so for the sake of clarity and so that you may educate yourselves on the subject its to do with logging and analyzing of an application or software which already supports the function.
in any event while you wasted your time actually jumping to conclusions, and for those really interested in an update on how i made progress. i managed to dump the proc 9s12 of the ecu and found the routines which allow me to calculate the seed/key algorithm for flashing the ecu. i would appreciate if anyone can offer some seednkey pairs and also just seeds, so that i can calc the key and give it to you to confirm if my calculations are correct. it seems the algo is for CAN and not VPW.
in the meantime i am looking into the chksumm algorithms.
I looked for clues to where the algorithm code was, but had now luck reverse engineering it. I knew where the seed and key were stored, as they were easy to find in the hex file. I then looked for areas that accesses those memory locations, still no luck.
You can remove a bolt and replace it with something better, why is software/firmware any different.
Yes, if you hack the code and develop a product from it, and capitalize on the work of others, then it's theft.
But if you're only modifying your bike, which you own, it's not theft.
my opinion....for what it's worth.
When you had a bike with a carburetor, and you put on bigger exhaust, for example, you had to put new jets in your carburetor, right? the jets cost you a little bit of money, and you probably had the to tools to put them in for not a lot of money.
the tune data in the ECM is no different than the jets in your carburetor. They affect how much fuel you engine gets. However, you have to buy very expensive tools to make the change! It should be affordable, just like changing jets!
I do also have a registered software to edit ECM file that is another 3000$, and what I'm looking for is to find documentation on ''harley'' specific file, they are called ''Damos, A2l,etc.. file) having the .bin file is ok, having the software to edit the file is ok, but to have map definition, factor & ofset of each map and their axis is another story, without this, you can't do much, as an example, If we need to increase the RPM cut off to 6000rpm, the value to search in the file maybee something like 58962 in hexadecimal, and we also need to know where it's located in the file.
If someone have any info on this, it will be appreciated.
Just a tip, we all know that chinese are copying everything they can, so it's possible for a DIY'er to find a cheap clone of what it's needed to read write harley ECM.
