Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
thanks for that update, i managed to dump the harley ECM and extract the seed/key algorithms which allow me to make my own flashing tool to read and write the harley ecm from the connector. i also solved the chksumm algorithms.
i am currently sourcing the DAMOS files the few i got were not correct but i should have something soon.
i am currently trying to dump the harley BCM if anyone has worked on that project
I have dumped my 2012 ecu and a 2009 via the back door, have not quite figured out the maps and reflashing yet. Willing to do some work if you want to share. I have a powervision as well
Good work!, I hope you are still active on this forum, i would like to help make this along. I have a CAN bus tool and am quite confused by the unlock algorithm. Lots of things are cool and don't require the unlock key for doing diagnostics, but is required for changing settings, even something like the automatic compression release.
Hello, this post was interesting. I hope you have made progress on the projects involving communication with the ECMs. Did you communicate with the MT21 M in 2021? For the past few weeks, no one has been able to read the HD 2024, the first difficulty was with the 121 CVO...
Hi,
I was wondering if you would be able to share the seed key algorithm, I am developing a flash tool for HD Motorbikes.
Quel type d'outil développez-vous, un outil de lecture et d'écriture ? En avez-vous déjŕ développé un pour lire les disques durs en J1850 également ? Solution brute ou cryptée ?
