2003 with unknown security code
Old Nov 24, 2012 | 10:40 AM
WVChrome's Avatar
WVChrome
Default 2003 with unknown security code
I have a 2003 Dyna with the security system and push button fobs. I have two fobs, but the security code is unknown as the previous owner never used it. HD says there is no way to find out the code once lost and there never was a factory default code, is this true? I've heard of others relearning the password before, so I'm confused on what they are telling me.
Later,
Chrome...
Old Nov 24, 2012 | 10:45 AM
kwo51's Avatar
kwo51
Look in the service manual it tells you how to find and chance codes.
Old Nov 24, 2012 | 02:37 PM
WVChrome's Avatar
WVChrome
I must be missing it, or it's in the owner's manual (which I don't have). All I see is how to set/disarm the system using the code without the fob. I don't know what the code is.
Later,
Chrome...
Old Nov 24, 2012 | 02:49 PM
UltraNutZ's Avatar
UltraNutZ
This will NOT work if you don't have FOB that was programmed for this security module. with assigned FOB in hand;
1. turn ignition key on, off, on, off, on
2. press left turn signal button 3 times
3. press button on FOB 2 times
current PIN will appear on the odometer
Old Nov 24, 2012 | 02:51 PM
kwo51's Avatar
kwo51
If you have access to any harley friends owners manual look in the changing pin setting. you can find this info here if you research the past posts
Old Nov 24, 2012 | 03:17 PM
WVChrome's Avatar
WVChrome
This worked (sort of). The PIN didn't flash on the odometer, but each time I double clicked my FOB, the signals flashed the next digit, and the key light flashed the assigned PIN for that digit. What do you know, it was 11111. Sure looks like a default code to me.
Anyways, big thanks for the help to you guys. After looking at the manual again, I learned I need better reading comprehension. I had seen the directions to change the code, but I was operating under the assumption I'd need the old code to do that (wrong, and the manual doesn't even mention the old code in the instructions).
Thanks for the help guys.
Later,
Chrome...
gr8filed
Mar 13, 2016 12:01 PM
2009FLSTSB
May 19, 2013 09:14 PM
rangemaster
Aug 4, 2010 01:19 PM
typennies
Jul 12, 2010 01:06 PM
roadrunner68
Apr 12, 2007 07:31 AM
