Copying data from one cal type to another
My 07 FLHX uses TTS 176 type cals
I have SE-204 cams
The only cal listed that is spec'd for 204 cams is CQD242-01
Which data should I copy from this 242 cal into my 176 type cal to take advantage of the 204 settings?
BTW I already noticed that some ranges are not the same etc, so it's no a plain copy paste.
I assume that at least the following two should be copied, please advise if any other is required or suggested.
CamTune settings, in this case 2-2
VE tables
