Magneti Marelli
Old Aug 7, 2014 | 06:34 AM
  #31
jp13's Avatar
jp13
Not sure what map they put in, I am sure it was the starter one. He told me they will try other ones until they get the correct one.Looks like it would be cheaper to have it dyno'ed if they charge me everytime they put a new map in.
Old Aug 7, 2014 | 08:17 AM
  #32
ajayrk's Avatar
ajayrk
You can load the maps your self. Did they give you the CD with the software? If not, download the Pro Tune from s&s and study it. You will need a usb cable to connect to the ECM. It's not that hard, select a map from the list and send it to the ecm.
Your map sounds lean.
Try this map: ECM: 55-5120A soft: A840 sn# 00051125 32709-99 DOM 1450 TC Stage 2 H-D USB ECM Domestic 1450 TC Stage 2, SE Air Cleaner, 203 cams
http://www.sscycle.com/tech-info/software/
A dyno tune by some one familiar with the S&S VFI would be a good idea.
Old Aug 7, 2014 | 01:15 PM
  #33
jp13's Avatar
jp13
Thanks I will give it a try.
Old Aug 8, 2014 | 07:35 AM
  #34
jp13's Avatar
jp13
I am brining bike up today, I will give them this map, hope this works with what I have. How many maps with this new ecm 41000012a, I cannot find anywhere on the internet.
Old Aug 8, 2014 | 08:59 AM
  #35
ajayrk's Avatar
ajayrk
The CD that came with the ECM has maps on it, ask for the
CD, you paid for it. It also has the Harley software that you load onto your computer and you can connect with the ECM, load maps adjust fuel, timing and other things.
I forgot to mention that the maps listed in the S&S software will not work with the Harley ECM even though the Harley ECM is built by S&S. Only the maps on the Harley CD will work. The S&S soft ware will allow you to go advance.
Old Aug 8, 2014 | 09:08 AM
  #36
ajayrk's Avatar
ajayrk
I will try to attach a map file.
And it did not allow that kind of file.
I you need, I can email the maps if you PM with your email address. It would be best to ask for the disk.
The CD part number is: 41000013
muaymendez1
Carburetor Related
Apr 9, 2018 12:06 PM
buba6
Exhaust System Topics
May 27, 2010 03:58 PM
swanie
May 19, 2010 08:28 PM
MGN54
Dec 12, 2009 07:28 AM
jmiller2001
Jul 14, 2009 11:37 AM
