Road King starter
Old Apr 12, 2013 | 10:50 AM
RonJD's Avatar
RonJD
4th Gear
Default Road King starter
I have a 2003 Road king, when I hit the starter it sounds like loud popping. I can get to the post on top of the starter, cleaned and retightend it. My question is can I get to the other post to clean and tighten? From my service manual it appears to be near the bottom of the starter. Thanks for any help.
Old Apr 12, 2013 | 10:59 AM
Scrmnvtwins's Avatar
Scrmnvtwins
You have a starter and solenoid assembly. The starter has a main battery connection on the top and transfers that to the starter through the solenoid. Pull the end cap off the right side of your starter and check the connections in there. Disconnect the battery vbefore pulling the cap. There is a spring loaded plunger assembly that has a copper shoulder that connects the 2 copper terminals when you hit the start button and energize the solenoid. Try cleaning the connections made by the t copper tabs and the plunger or just buy the rebuild kit which will have a new plunger and 2 copper terminals
Old Apr 12, 2013 | 11:02 AM
Scrmnvtwins
The plunger is under the chrome cover in the attached picture
Old Apr 12, 2013 | 02:32 PM
RonJD's Avatar
RonJD
4th Gear
Thanks so much, will try it. After my first post I thought I should have said clicking not popping. Will try that tomorrow since its pouring rain here in Central Fl. Will post the results. Thanks again
aspiringthomas
May 3, 2019 09:17 PM
97Heritagerider
Electrical/Lighting/Alarm
Apr 16, 2017 08:26 PM
chrisfharley
Engine Mechanical Topics
Apr 7, 2014 05:02 PM
thclela
Aug 8, 2007 03:37 PM
lennox5024
May 23, 2006 02:21 PM
