road king starter
Old Aug 8, 2007 | 01:08 PM
thclela's Avatar
thclela
Stage I
Default road king starter
02 road king starter stays engaged as long as the key is on. I figure its a fried relay. Anyone had this problem?
Old Aug 8, 2007 | 02:11 PM
jetboy100's Avatar
jetboy100
Stage II
Default RE: road king starter
I am having the exact same problem on my 02 Road King. I got the starter relay yesterday. I'll put that in and hope that's it, however, I can't get the starter out to see if any damage has been done to the starter gear. I have all the hardware off but the starter will not slide far enough to the right to raise it out of it's location. I'm thinking that the starter gear is still extended, will need to be retracted to pull the starter itself out....good luck amigo.
Old Aug 8, 2007 | 03:37 PM
stafford's Avatar
stafford
I had the same problem, everyone said I pinched a wire at the switch housings but that isn'twhat it was. I just unplugged the wire from the solenoid to keep it from starting. Come time to start it I'd just touch the wire to the solenoid. It was a lot of trouble. Finally got tired of it and started seriously checking it and found the starter button itself to be the problem. about 40.00 dollars and an hour or so to change.
aspiringthomas
May 3, 2019 09:17 PM
NickSchoff
EVO
Apr 5, 2013 08:26 AM
RRamsey
Oct 21, 2012 08:42 PM
harrisj
Jan 26, 2010 05:06 PM
kingkingking
Sep 29, 2009 06:28 AM
