Help getting aggrevated
Old Aug 18, 2005 | 09:09 PM
Lizpereira's Avatar
Lizpereira
Stage II
Default Help getting aggrevated
Hi guys, having a small problem with a 1971 XLCH 1000 sportster. The bike decharges itself. The bike has been all rewired, new generator, new regulator. Now we don't know where to go from here. Any suggestions would be appreciated.
Old Aug 18, 2005 | 10:01 PM
John TN's Avatar
John TN
Default RE: Help getting aggrevated
Apparently it's not charging or appears not to be, see what the battery voltage is with the engine off and then what the voltage is with the engine running at idle and then at slightly rev'ed up. I know you have replaced everything, but sometimes the charging system is good and there is something else that is causing the discharge.
Old Aug 20, 2005 | 05:34 PM
HDF Tech's Avatar
HDF Tech
Have you polarized the generator yet?
With the generator and regulator hooked up as usual, make a jumper wire and connect one end to the generator "Armature" terminal . Momentarily touch the other end to the positive terminal of the battery and if everything is OK mechanically, this should do it.
Old Aug 21, 2005 | 01:28 PM
Lizpereira's Avatar
Lizpereira
Stage II
I have tried polarized the generator. That didn't work. Also tried the volts as far as the bike running and reving! Totally lost now have no clue why this bike is decharging after 1/2 hour of riding.
Old Aug 21, 2005 | 02:29 PM
HDF Tech's Avatar
HDF Tech
Only thing else to try is a continuity check of all the wires in the circuit or the brushes in the generator if you have one hanging up. It may not be that the system is discharging , it may be that it isn't charging at all.
Miker7
Nov 28, 2018 04:18 PM
Tyler.xvx
Jun 16, 2012 08:32 PM
dksportster
Jul 5, 2011 05:11 PM
Astro
Oct 10, 2010 07:08 PM
dksportster
Welcome Area Only
Jan 4, 2008 01:33 AM
