Crazy charging problem
Old Jul 27, 2013 | 01:35 PM
Got2bshane's Avatar
Got2bshane
Stage I
Default Crazy charging problem
2006 street glide. I noticed noise that seemed to be a loose primary chain. Like a grinding sound when I let off of the throttle. I tightened the chain a little and the sound continued for a couple of days and all of a sudden went away. Then I started noticing after start up the engine light would come on for a couple of seconds and then go out. This lasted for a couple of days and yesterday I started the bike to leave work, the engine light came on and went off and everything seemed normal. About 40 min into my ride home I noticed the engine light on and I was only charging at about 10 volts. I got off of the interstate about 5 miles after that and the gauge read about 8 volts. I made it 4 more miles home and shut the bike off. I charged the battery and started the bike today. The voltage read pretty steady at about 13.8 while at idle after a few seconds I hit the throttle and the voltage immediately came down to 12.6 volts and then just continued to fall until I shut the bike off. Any ideas? Thanks in advance for the help.
Old Jul 28, 2013 | 12:14 AM
LightningRider's Avatar
LightningRider
6th Gear
Bad stator or regulator or both. You need to test them to figure out which one is the problem.
Oldgreazer
General Topics/Tech Tips
26
Apr 14, 2017 05:45 PM
kbluense
Nov 7, 2013 02:43 PM
zeus33
Electrical/Lighting/Alarm
Aug 6, 2013 10:04 AM
MidnitEvil
Oct 9, 2009 07:53 PM
BigFokker
Aug 9, 2008 01:29 PM
