Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
At 1st, the problem was intermittent. After start up, sometimes the speedo wouldn't work so I'd restart it sometimes a few times until it started working. Now, no speedo or speedo light or 6 speed light. Do you think it's the speed sensor or, the speedo itself?
It could be either. Does the needle sweep when you turn the ignition on or does it stay still? Do any of the lights turn on? There is a speedo test module that can be hooked up that will run it through some tests.
It pretty much stays still. Maybe twitches a little but, it doesn't sweep. There are lights until it's started and running then nothing.
