running lean
Old Mar 26, 2007 | 11:40 PM
soft 02's Avatar
soft 02
Default running lean
i just installed v&h's big shot staggerds and big sucker with se's #67 map. bike runs great but i pulled the plugs to check and they are white. went back and maxed out the o2 bias table and went for a five minute ride with no change. does any one have a better map. ore some advice. or am i bieng overly anol.
Old Mar 26, 2007 | 11:41 PM
soft 02's Avatar
soft 02
Default RE: running lean
oh i have a 07 fxst
Old Mar 27, 2007 | 03:14 PM
ebodiford's Avatar
ebodiford
6th Gear
What do you mean burning white? Are they just clean or actually turning white? I have the baffles out of my O7 Fatboy and the plugs are clean after 1200 miles, but not white.
Old Mar 27, 2007 | 09:47 PM
cjuetten's Avatar
cjuetten
my .$02
These motors were designed to run lean. You have the correct map for you setup. Run it some more and check them again. Dispite all the screaming about the 07 running hot and lean (which they do) doesn't seem to be any failures related toit. Chances are good your running richer than it did out of the crate.
An old gearheadmoto "Give the motor what it want" If its running great I think you've done just that.
Old Mar 27, 2007 | 10:56 PM
Shovelhead Bob's Avatar
Shovelhead Bob
First off... A 5 minute ride isn't going to tell you squat...
I have said it before, and I keep saying it.... YOU CANNOT TELL IF IT IS FAT OR LEAN BY READING THE PLUGS......
You need to use an o2 Meter.... That is the only true accurate way to read what your Exhaust gas' are comprised of and how they are mixed.....
Take your pc out with you, and record o2 Data Mode.... You will see what the o2 Integrators are doing, to tell you if it is dire need of tuning...
Old Mar 28, 2007 | 12:29 AM
soft 02's Avatar
soft 02
thanks guys . yea after putting some miles on her she runs awsome. i undestandfrom reading other posts that you cant read plugs. my afr looks good and the knock retarder doesnt seem to be active so i guess everything is ok. just didnt want to hurt anything. she's my daily driver . thanks again.
Old Mar 28, 2007 | 12:46 AM
2.wheels.of.love's Avatar
2.wheels.of.love
Or you could tune it right with a dyno so you really know whatis going on. Its kind of an expensive part to be playing a guessing game with. THE MAPS THEY PROVIDE ARE JUST AN EXPENSIVE DOWNLOAD. IF YOU WANT A CUSTOM INTAKE,EXHAUST AND OR MOTOR WORK
!!!!!!!!!!!!!!!!!YOU NEED A CUSTOM MAP!!!!!!!!!!!!!!!!!!NO GUESSING
rsking45
Jul 25, 2014 08:22 PM
az_steve
Aug 1, 2013 09:08 AM
UltraDune
May 15, 2011 03:05 AM
SGJake
Sep 25, 2010 11:25 AM
soft 02
Mar 27, 2007 11:53 PM
