SERT MAP
Old Mar 27, 2007 | 06:42 PM
sprint12's Avatar
sprint12
Default SERT MAP
Anybody have the 159AE003-A1 map off the H or J cd I could get my hands on? I ordered the J cd today, I won't have it for 2 weeks.
Thanks!!
Old Mar 27, 2007 | 07:20 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Default RE: SERT MAP
ORIGINAL: sprint12
Thanks!!
Greg,
The 159AE003-A1 is found on the "J" CD(the one you are looking for), as I have the "H" CD and it only contains the 159AE003-A0.........so you need someone with the "J" cd to hook you up till yours comes in.
Old Mar 27, 2007 | 11:54 PM
badmo's Avatar
badmo
I have it. Shoot me a pm if you still need it and I will e-mail it to you.
Old Mar 29, 2007 | 08:20 PM
SonnyMax's Avatar
SonnyMax
Does anyone know if map 78 on the J disk is the same as the map on the H disk? Or is there another map similar to 78 that can be used with SE a/c and SE pipes for an -07 that is an improvement?
Old Mar 29, 2007 | 08:54 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Map #78 on both libraries are for the same set-up... It's just that the map has been updated with a better and broader closed loop area, and the "Torque Smoothing" has been applied...
Old Mar 29, 2007 | 09:37 PM
UltraKla$$ic
ORIGINAL: Shovelhead Bob
And just to reiterate, the 159PZ004(cal #78) off the J Cd is a MUCH better map than the 159PZ003 map from the H Cd..............MUCH better.
Old Mar 30, 2007 | 07:12 PM
SonnyMax's Avatar
SonnyMax
Thanks, Shovel and Ultra. Guess I will have to get the J disk.
Old Apr 2, 2007 | 06:00 PM
cjuetten's Avatar
cjuetten
ORGINAL UltraClassic
I just got done replacing 159PZ003 withMAP 159PZ004....WOW. The difference in the lower RPMs is night and day. 6th gear can now be used under 2500RPM. No more Knock Retard, pinging or trans chatter. Much smoother between 2000-2500rpm......actually runslike a stroked 96" motor.
Old Apr 2, 2007 | 06:19 PM
johnny canuck's Avatar
johnny canuck
I have ordered the 'G" version of SERT. Will I receive the
"J"CD with this kit?
SHB, my combo is V&H Ovals with a Ness Big Sucker on a 07 Ultra. Map 78 will be the best as a base map , right?
I asked dealer if they would max out O2 tables to 798 and their response was whyI would want to introduce this much fuel in to the cylinders.
Commens would be appreciated.
Thanks
Old Apr 2, 2007 | 06:48 PM
Shovelhead Bob
ORIGINAL: johnny canuck
Thanks
Yes, you will get the "J" software...
78 is your starting point....
Because they don't know the system (Closed Loop o2 Feedback), and do not have anyone trained by HDU.... Plain and simple....
Just out of curiosity, why are you having the dealer do the work, are they gonna dyno it as well????
If so, I would suggest to you that you find some other shop that is PROPERLY trained to do the tune....
You can do all of the work yourself, as the dealer service staff has already shown that they are unfamiliar with the SERT....
