Ironhead A place to talk about Ironheads.
Spark Problem
Old Oct 1, 2014 | 07:49 PM
dukeinhaler's Avatar
dukeinhaler
6th Gear
Default Spark Problem
1969 XLCH. New plugs gapped at .020. New points .015 gap, new condensor. New 8mm plug wires. Made sure timing is correct. I only get a good spark once out of ten kicks. (plugs removed and held against jug). My right leg is now twice the size of my left leg! Talked to a Harley Mechanic at the dealer today and he had no idea but also told me he has never worked and a bike older than 1997!!!! Could the coil in the magneto be bad?? Any other ideas out there? ANY HELP would be appreciated. Thanks
Tom
Old Oct 1, 2014 | 08:09 PM
johnjzjz's Avatar
johnjzjz
two things to check and or disconnect for the time being
first if you have a key to shut the mag off dis connect it< could be shorting had that happen
the handle bar kill switch could also have a split in the wire and it will kill the mag run a new wire to a toggle switch and see if that works < had this happen as well
Old Oct 1, 2014 | 08:22 PM
IronMick's Avatar
IronMick
Deleted it.
Old Oct 1, 2014 | 11:27 PM
dukeinhaler
6th Gear
Have done both of those things. No change. Thanks for the help.
Tom
Old Oct 2, 2014 | 03:20 PM
johnjzjz's Avatar
johnjzjz
did you add a ground wire to the MAG had that issue as well - you would think it is because of how its attached its fine well its not in some try that
Old Oct 3, 2014 | 06:33 PM
dukeinhaler
6th Gear
UPDATE:
1969 XLCH last ran 1980. Just finished getting the bike back together. Have not been able to start the bike. I have kicked it for the last three days. Hundreds of kicks. Not one fire. Asked for help here. Johnjzjz suggested I ground the magneto. Started on the 4th kick!!!! Johnjzjz thank you, thank you, thank you. You saved me an ulcer and a total knee replacement. I would have never thought the mag need to have an extra ground. There is so much good help here it is incredible.
Tom
Old Oct 3, 2014 | 07:18 PM
johnjzjz's Avatar
johnjzjz
Originally Posted by dukeinhaler
UPDATE:
Tom
glad to help -- jz
Old Oct 4, 2014 | 07:06 AM
IronMick's Avatar
IronMick
I love hearing these success stories. Nothing like the look, sound and feel of an IronHead. How about posting a nice video of the starting process, and especially including the sound of it running
48 Special
Apr 13, 2016 07:01 AM
pizablo187
Electrical/Lighting/Alarm
Jul 31, 2009 07:50 AM
shovelpan
Nov 26, 2008 06:37 PM
chamberlinjohn
Aug 29, 2008 07:56 PM
761lowsporty
Aug 8, 2006 06:36 PM
