Ironhead A place to talk about Ironheads.
Right hand shift ?? (year ended)
Old Oct 28, 2007 | 10:22 AM
LeeZach's Avatar
LeeZach
1st Gear
Default Right hand shift ?? (year ended)
I have a 75 Ironhead with the right hand shft. What was the last year they made right hand shift? Was 75 the last year? Some people say74 was the last year, and I can't have a 75 right hand shift. Ive look on the web for info but I can't find any. Thisis my model number(4A12074H5) I found it on the web and it is a 75. They had me thinking that I had the wrong year. Thanks
LeeZach
1975 Ironhead
USAF 86-07
Good decisions are learned from experience.
Experience is learned from making bad decisions.
Old Oct 28, 2007 | 10:33 AM
pococj's Avatar
pococj
Default RE: Right hand shift ?? (year ended)
1975 was indeed the first year for the left hand shift. But it was a cobbed together pice of crapola that worked marginally at best, and as parts wore sometimes quit working altogether. It was an easy job to gather the parts and convert it back to a right side shift/left side brake. That is probably what was done on your bike.
Old Oct 29, 2007 | 02:21 AM
Moon Wolf's Avatar
Moon Wolf
Yep. The only change to make the '75 a left hand shift was a goofy linkage that used the original brake pivot. I believe the DOT mandated the change, and it was done on short notice. There's no difference in the motor or the actual shift location.
Old Oct 30, 2007 | 10:37 AM
LeeZach's Avatar
LeeZach
1st Gear
That makes (cent $$) Sometimes the cheap and easy way back is the best. Thanks guys,
Old Nov 2, 2007 | 06:57 AM
carlgrover's Avatar
carlgrover
Funny thing about that crappy linkage on the 75. I've had mine for over 25 years and never had one problem with it. I guess I'm just lucky. Now that I've mouthed off, it will probably break on me
Old Nov 2, 2007 | 08:01 AM
oldbikenut's Avatar
oldbikenut
There's no reason that the external linkage won't give good service, if it is adjusted properly and lubed occasionally. The shifter on my 76 still works smooth as silk.
Old Nov 2, 2007 | 12:36 PM
pococj's Avatar
pococj
ORIGINAL: ironxl
How many miles on this bike?
Old Nov 2, 2007 | 02:02 PM
Bluzmn59's Avatar
Bluzmn59
Interesting. I had a '74 and thought that was the last year. I had never heard about the problems with the '75's. Learn something everyday, I guess.
Old Nov 5, 2007 | 05:35 PM
Oldtimer of NM's Avatar
Oldtimer of NM
The '75s didn't come from the factory with a righthand shift for delivery in the US. It was a DOT thing that mandated standardized shifters on all bikes and cages starting in the '75 model year, so it may be that a few were shipped to other market areas with the right side shifter. Also, on '75 and '76 Sportsters, the way the factory did the conversion to a left side shift made it very easy to convert to a right shift if you needed or wanted it.
Old Feb 26, 2009 | 10:48 PM
pamasa's Avatar
pamasa
1st Gear
Default right side shifter
i have a right side shift sporster. the vin # starts with 4A on the motor only have 7 digits last 2 are unreadable.have read that 70,71,72 were all 900s and 1000cc came later after 72.how can one tell the difference
