Ironhead A place to talk about Ironheads.
Leaks oil!
Old Dec 10, 2007 | 04:05 PM
bykrdan's Avatar
bykrdan
Default Leaks oil!
Hello again;
I have a pretty serious oil leak going on and wanted to check with you all before I take on any unnecessary work. This leak has developed gradually and drips down around the back of the motor, real close to the primary drain plug. In fact, I replaced the gasket on that plug and sealed up the threads with some Teflon plumber's tape, but the leak proved to be coming further from the right of the engine. I had also suspected the chain was just throwing oil off in the sprocket cover, but this is way too much now to be that. Plus, my primary/transmission oil does run out over time.
I'm now looking hard at the sprocket seal. Does this sound right to you? It doesn't look like a big job, but I do hate to go poking around and replacing parts I don't need.
While I was looking at the motor, I did discover I also have a missing gearcase bolt - I'll get that replaced tonight, and it might also be a leak point, but I do not see the amount of oil I'd expect on the outside of the motor if that were the case.
Thanks,
Dan.
Old Dec 10, 2007 | 04:14 PM
83XLX's Avatar
83XLX
Default RE: Leaks oil!
Could be the sprocket shaft seal. They will wear out fast and leak worse if the chain's run too tight. Before replacing the seal, see if your chain is too tight. If it is, slack off on it a little and see if the leak slows down or stops.
Old Dec 11, 2007 | 10:51 AM
bykrdan's Avatar
bykrdan
Thanks for the reply; I don't think my chain is overly tight (at the moment) though it probably has been at some time in the past. And I know I've never changed that seal in the ten or so years I've had this bike. It's a '79. Something tells me that seal has never been replaced...
Old Dec 18, 2007 | 12:13 PM
bykrdan's Avatar
bykrdan
An update - I replaced the missing gearcase bolt and found that ALL of the remaining bolts needed some tightening as well. They all turned in about 1/4 to 1/2 turn.
The leak has been greatly reduced - to a few drops after each ride, down from a puddle!
So, what does everybody here use to clean up oil off the concrete? :^)
Old Dec 18, 2007 | 12:27 PM
wbogley's Avatar
wbogley
ORIGINAL: bykrdan
So, what does everybody here use to clean up oil off the contrete? :^)
bykrdan,
Get a epoxy floor in your garage. The are real sweet!! Oil cleans up with a paper towel.
Old Dec 18, 2007 | 08:31 PM
hog4u's Avatar
hog4u
I burn it off with my rear tire. ;-)
Old Dec 21, 2007 | 03:25 PM
bykrdan's Avatar
bykrdan
I don't think I have enough Avon left for that!
vindyl
Feb 26, 2011 10:31 PM
sportster77
Ironhead
Apr 19, 2009 05:38 AM
supr2nr
Ironhead
May 11, 2008 10:53 PM
Tn.Heritage
Apr 30, 2007 05:31 AM
nickdv9
Feb 10, 2007 12:56 AM
