What sportster engine is this
click attachment 1 to see the VIN #
[IMG]local://upfiles/49829/64856483F1E74213A74C17ABB35A3056.jpg[/IMG]
What sportster engine is this, just purchased a basket, it's a mix of years, the VIN numbers on the right side case are 560 xx2 x35, it's not like the frame 4AxxxxH2. (1972 frame) Inside the case, above the trans, there is a casting number, 24xxx-72. Have a dual disk frt end, what years were they used? I'm going to see if it's worth putting together, if not I'll be selling the parts piece by piece. Thanks !
Seems I remember the pre '70 models VIN would be first two numbers = year, then next 3 or 4 letters = model, and last numbers are production run number. Your supposed VIN doesn't match either this type, or the '70 - '80 type, and definitely not the later than '80 years. That would have me worried, unless I had papers saying the cases were aftermarket.
Looks like the dual disc front end is a Wide Glide type, though it could be a Sporty modified that way.
This much I am sure of: The engine is 1971 (1971= 900cc) or newer. The engine number you gave is not correct for a seventies engine either.
The frame is a 1972 XLCH according to the number you stated.
Looking at the primary side of things, the casting number does not mean too much. About all you can say is that it was made in 1972 or later. So now we have a 1972?
From the photo is seems like there is no breather screen between the crankcase and the primary compartment. No screen means it is 1977 or newer and if so, there should be a vent connection in the top of the transmission case.
I think your engine has the breather though (maybe it was remover to do the bead blasting) and the engine is somewhere between a 1972 and a 1976 and will not have a vent connection because these models shared engine oil (to a small extent) with the crankcase and the primary/transmission via the vent screen breather.
So, my conclusion is.............the engine is a 1972 (1000cc) with a funny engine number? That year would match the frame, and the front end is certainly off something much newer and 1978 is a good guess on that.......pg
You are correct regarding the engine number system used before 1970. Also correct about the number is not from the seventies or newer either.
What he has there is an engine that has seen a file and a set of number stamps put to use on it. It will be really hard to get this one titled I would think.
He could regrind the case and re-stamp the frame number into the case, but if the frame has only 4 digits in the serial part of the number it needs 5 digits and Harley used a funny looking '8' laid kinda sideways to denote that 5th digit. Hard to find that kind of stamp anywhere. Besides being illegal, it will still be difficult to get a title even if the numbers do match. For the record, I do not advocate stamping the engine number on the case!
On the other hand if he has a good title that matches the frame number, he is almost home free. As a practical matter, if it were in Texas the DMV will never go out and look at the bike. In California though it is a different situation, so it all depends which state he lives in.......pg
i will go into detail later. That bike was in iron works magazine, had another iron head softail in hot bike,. Anyhow, if you want to build it, do it. Most will tell you not to bother and save your money. I say do what you want. They are good bikes and are a lot of fun.
Be well, and dont hesitate to e-mail if you have any questions i can help you with.
There is nothing i havent done to iron heads in the past, stroke, big cames, thunderjets, cutting the tranny off and running a bog twin tranny, modifying the frames cutting the rocker boxes in two.. all kinds of stuff. I dont mess with them any more but it was fun.
Motor numbers look OK to me. 4A means XLCH. Last digit is the year. It is a 1972 XLCH motor.
