Ironhead A place to talk about Ironheads.
cam question
Old Feb 17, 2008 | 01:59 PM
roofer's Avatar
roofer
Default cam question
I have a 1983 xls with q cams if I put in p cams do I need to put in all new bushings and bearing and what makes the p cams better. Thanks for any help
Old Feb 17, 2008 | 05:27 PM
supr2nr's Avatar
supr2nr
Default RE: cam question
no reason for new bearings and bushings unles they are just already in poor shape. If they are okay then they will be fine to be kept in there. However you will have to measure the free end play and be ready to re-shim all of the new cams.
The difference in the cams is torque (power). P Cams allow for higher torque and in turn for a more responsive power at the rear wheel. The Q cams like was mentioned in my thread were not responsive at all and were changed out by most people quite often.
Old Feb 17, 2008 | 05:43 PM
roofer's Avatar
roofer
Thanks for the info
Old Feb 17, 2008 | 06:18 PM
supr2nr's Avatar
supr2nr
no problem man! I'd like to see your bike when you get all done. Good luck to yah.
Old Feb 18, 2008 | 11:08 PM
roofer's Avatar
roofer
Where can you find ps cams all I ever see are the p cams on ebay and what is the differance and the years the ps were used Thanks for any help
Old Feb 19, 2008 | 08:45 AM
SportsterBob's Avatar
SportsterBob
Just for the sake of discussion, years ago I bought a set of NEW Andrews PB+ cams for my 900. After going thru the installation and spending all that money, there was NO DIFFERENCEin performance compared to the stock P cams. Eventually I put the stock P's back in and thay have stayed there since.
fxd666
Engine Mechanical Topics
Apr 24, 2015 09:54 AM
BLACKTOP GLIDER
Apr 9, 2010 12:45 PM
AdrianVall
Jun 24, 2008 06:31 PM
fj4069
Exhaust System Topics
Mar 17, 2008 07:10 AM
pauletich
Aug 10, 2007 04:53 PM
