Ironhead A place to talk about Ironheads.
Primary fluid level?
Old May 16, 2008 | 12:03 PM
Skinner's Avatar
Skinner
Default Primary fluid level?
I have hard-tailed my '76 sportster and put a 21" wheel on the front. So now it dosen't sit "as level" (lower in the back end) as it did stock.
Should I still use the fill level screw in the primary?
OR
Should I just add the 24 oz (1.5 pints) as specified in the book.
As a side note, it willhold 32 oz (2 pints) when I fill it up to the fill level screw.
Skinner
Old May 16, 2008 | 08:30 PM
piniongear's Avatar
piniongear
Default RE: Primary fluid level?
Just use the 24 oz (or 26 oz) as it states in the book. If the rear sits a little low due to the frame all the oil will still be in the transmission and back under the clutch basket/sprocket and believe me, there is going to be plenty of oil for the primary items. You are OK with that. DO NOT put 32 oz of oil in there. It is way too much.........pg
Old May 17, 2008 | 09:09 AM
Skinner's Avatar
Skinner
Thanks PG. As always, you have come though again. Much appreciated.
Skinner
marxman
Jun 21, 2017 09:46 PM
bpd138
Oil Archive (no new posts)
Jun 5, 2014 08:43 PM
Electra1
Oct 23, 2011 09:17 AM
Frankster69
Aug 29, 2008 09:42 PM
pro1955
Nov 29, 2006 03:26 PM
