Ironhead A place to talk about Ironheads.
Starter Relay !!
Old Jun 3, 2008 | 08:27 AM
piniongear's Avatar
piniongear
Default RE: Starter Relay !!
What would hapen if the cables on the starter relay where switched around?
I am not sure what effect it would have switching the relay wires around, but the battery cable connects to the longest stud on the solenoid.
If you connect this cable to the shorter stud, the solenoid remains in the battery circuit....not good...........pg
edit note: You should have the relay installed. I recommend you get one and wire it into the circuit asap.
Old Jun 10, 2008 | 06:50 PM
sutphen30's Avatar
sutphen30
alright so get this!! I have power going to the relay 1 large post only and the small terminal that runs to the switch is power as well all the time?? the other terminal that runs to the Solinoid has no juice at all ?? therefore no juice to the starter?? Any quick thoughts on what I may have done wrong??
Old Jun 10, 2008 | 08:15 PM
supr2nr's Avatar
supr2nr
sutphen, check your email.
1unclejojo
Shovelhead
Sep 6, 2012 07:52 PM
jsa750k
EVO
Oct 8, 2011 06:02 PM
inthamix
Ironhead
Apr 7, 2009 04:33 PM
SirEagle
Shovelhead
Oct 9, 2007 11:37 PM
saweet96
Jul 15, 2006 03:20 PM
