Ironhead A place to talk about Ironheads.
neutral lite
Old Jun 29, 2008 | 07:58 AM
98glider's Avatar
98glider
Default neutral lite
I have a 84 bobber iron head and the bike is bare to the bones just a oil lite and a tail lite and head lite. My question is about the neutral lite. I cannot find the switch for it and in the manual I cannot find it. I thought bikes from that year had one. help would be Appreciated
Old Jun 29, 2008 | 08:27 PM
mojo2go's Avatar
mojo2go
Default RE: neutral lite
In 1984 the only indicator lights were oil, gen, &amp\\; hi-beam.
Old Jun 29, 2008 | 08:38 PM
piniongear's Avatar
piniongear
Older ironheads (1977 on....) sometimes had neutral switches, and sometimes not. This kept the ignition circuit open if the bike was in gear to prevent it from starting up in gear.
The neutral light you are looking for may have been put on a 1984 Sportster but I am not sure.
If yours had one then the sender connection is going to be somewhere on your transmission case, and most likely on the top side. If you see no threaded stud sticking out then there is no provision for a neutral indicator light.......pg
dave the welder
2014-2024 Touring Models
Feb 26, 2018 09:04 AM
fredflin
Electrical/Lighting/Alarm
Aug 9, 2016 11:25 AM
Jeff W
May 3, 2012 02:52 PM
510Sled
Aug 1, 2010 06:16 PM
French56
Mar 6, 2008 02:14 PM
