Neutral light comes on
Old Feb 25, 2018 | 06:48 PM
dave the welder's Avatar
dave the welder
Default Neutral light comes on
Recently on my 2015 RK, with 15,000 miles. The neutral has come on, I notice it when cruising along. If I have the gear position activated it will flash as well. What should I look for?
Old Feb 25, 2018 | 06:58 PM
cycle7447's Avatar
cycle7447
Community Influencer
Not being a wise guy - but, I would look for my nearest dealer - if the unit is under warrenty
Old Feb 25, 2018 | 07:18 PM
dawg's Avatar
dawg
Neutral switch?
Old Feb 25, 2018 | 07:34 PM
Randol's Avatar
Randol
Most other bikes I have worked on have a neutral switch that grounds when in Neutral. Check for a chaffed or pinched wire shorting to ground. Pretty sure the neutral sw is on top of the trans, right side.
Last issue I had like this was on a Victory. Oil pressure sw. wire chaffed on the swingarm, wore through the insulation and shorted it to ground, causing the oil pressure light to come on intermittently.
Old Feb 25, 2018 | 08:01 PM
Radiochris's Avatar
Radiochris
Left switch pack.
Old Feb 26, 2018 | 06:16 AM
top0211's Avatar
top0211
Left switch pack.
Old Feb 26, 2018 | 08:12 AM
dave the welder
Thanks for the reply's, the left switch pack is that on the handle bar? Also going to check the neutral switch.
Old Feb 26, 2018 | 08:44 AM
dawg's Avatar
dawg
Yes, left switch pack is the left handlebar controls. HD has had problems with left switch pack failures in the Rushmore’s.
Old Feb 26, 2018 | 08:58 AM
tpcowfish's Avatar
tpcowfish
Did you check if the switch for the odometer on left switch pack works, reset, change from odometer, a and b ?
Old Feb 26, 2018 | 09:04 AM
BigMike's Avatar
BigMike
The neutral switch is on top of the trans behind the back cylinder and has two wires going to it. Remove the wires and see if it goes out. It could just be a bad neutral switch. Takes 10 minutes to change.
Gil Lamb
Jun 4, 2019 02:13 PM
yso191
Sep 13, 2009 09:09 PM
stevepacman
May 24, 2008 12:24 PM
ultraclassicrider
General Topics/Tech Tips
Feb 15, 2007 12:52 AM
Harley Dad
Jul 27, 2005 12:47 AM
