Ironhead A place to talk about Ironheads.
Generator Leak!!
Old Jul 10, 2008 | 01:28 PM
98glider's Avatar
98glider
Default RE: Generator Leak!!
Also pinion gear do I have to do this to every wire that I disconnect including headlites etc. I just want to make sure that I am aware of different procedures of the gen. I have a98glide and I am not aware of different maintence for this bike. This bike has been taken apart and put together and the wiring all has been changed and I want to put blinkers with led lites and led brake lites etc Thanks pinion for your help as I do see alot of your discussions with problems of&nbsp\\; people bikes and giving excellent advice.
Old Jul 11, 2008 | 11:22 AM
piniongear's Avatar
piniongear
Let me restate what I said regarding removing wiring and flashing the field coils.
Anytime you remove wires from the generator or regulator you should flash the fields.
If you have only removed wires from your headlight you do not have to flash.
If you have installed a new battery or a new regulator you need to flash...........pg
Inop
EVO
26
May 29, 2025 08:36 AM
theterribleone_vdc
Aug 24, 2016 08:26 AM
jamala00
May 15, 2013 08:58 AM
Bulldog21
Aug 21, 2008 10:15 PM
opiate9680
Nov 3, 2005 07:38 PM
