Ironhead A place to talk about Ironheads.
Taking motor out
Old Oct 6, 2008 | 08:22 PM
dirty78ironhead's Avatar
dirty78ironhead
I laid down some 2 inch thick pading and put the motor on its side and dropped the frame over the top bolted up the rear mounts and stood it up. No masking no scratchs work out perfect.
T-Ron
Old Oct 7, 2008 | 12:16 AM
jones's Avatar
jones
I also laid my engine on its side and then laid the frame over top of it. I bolted all the mounts and then stood it up. I didn't have one scratch and I didn't mask a thing.
I wish I'd done it when I took it apart because it felt like 188lbs coming out.
Old Oct 7, 2008 | 05:43 AM
piniongear's Avatar
piniongear
Originally Posted by 98glider
Now you guys brought up a good point what about the motor mounts should they mask them off before painting what happens if i leave the paint on when I put the motor back in and the axle too
Mask off the motor mount area of contact. Do not get paint on this area, especially if you intend to use epoxy paint.
The epoxy has a definite thickness to it and this will interfere with mounting the engine correctly. Should you paint the mount surface, also expect the paint to crack around the area when the engine is installed.
Ditto that if you choose to use powder coat..............pg
Old Oct 7, 2008 | 12:46 PM
Moon Wolf's Avatar
Moon Wolf
I don't remove the paint from the rear motor mount and have never had any problem. In fact haven't thought about until now. I suppose the paint could be so thick that it affects motor placement, but in the past forty years I've never had that problem. As for the axle, you don't want any paint on it for the obvious reasons.
Pinion, I use PPG paint myself and am amazed at the durability. It also looks, at least to my eye, a lot better than powder coat.
Old Oct 7, 2008 | 02:37 PM
piniongear's Avatar
piniongear
Hi Moon Wolf......
Better than powder coat? Oh I totally agree with you!
A lot of people think powder coating is the greatest thing ever done to coat a frame. I really disagree with that.
I always use PPG products myself. Shoot a couple of coats of clear over the epoxy paint and it looks like it is an inch deep.
Now for color I use Color Concept as I said, but I do have one complaint with it.
This paint is really, really hard and that means it will chip easily when hit with gravel etc. My old Sporty and my trailer both have CC on them and while the bike is in good shape, the trailer has a bit of chips in the fenders from gravel.
PPG has a less 'hard' line of paint but the trade off there is it will not hold up like Color Concept, so I decided to stick with the CC myself.
I apply 2 to 3 mils of primer and about 4 mils of paint and a couple more of clear on a project. That starts to make a measurable build of thickness, thus the reason I always mask off the engine mount area myself. Maybe I could just paint it, but I am still doing it the way I was taught..............pg
Old Oct 7, 2008 | 03:17 PM
supr2nr's Avatar
supr2nr
Originally Posted by piniongear
Hi Moon Wolf......
Powder Coating isn't better than painting, but considering that its usually one coat, sometimes two, it actually has quite a bit of resiliance to foreign material. The real good thing about powder coating is the cost effectiveness of it and that it's easier.
Although I prefer paint, powder coating actually does a better job in some cases at resisting oil and gas than paint does. Not that I'm saying epoxy based paint isn't good at it, just that in some occasions powder coating is superior. Although, people are allowed to have their own opinions.
I still somewhat disagree with you on the baking of the parts with epoxy. I have been painting vehicles for a long time (granted not as long as you), but I still find my paint sets better and chips less if I "bake" it. I of course was exaggerating when I said my shed was 130 degrees. But 90-100 yes. This is why I quote bake. I know its not actually baking the paint as we used to do with enamel or lacquer but still the paint is baking in higher temps than the ambient temp.
On the paint selection. PPG is a great brand of paint and is easily accessible in that most auto body paint stores around town carry it. However, for color coat, I always and will always prefer House of Kolor.
But like I said we all have our own opinions. No one is neither wrong nor right!
Old Oct 7, 2008 | 09:46 PM
mojo2go's Avatar
mojo2go
I was looking at the motor today and I decided to give the thread a chance. Now you said the right, now do you mean tilting out the brake side right. I looked under the frame I did notice that the motor sits in between the frame and sits lower a little( the motor). Now how does it work out for this type of frame Do the orig frame motor sit the same way. Thanks for your help. I was going to get one of those lifts that lift the hole bike to give me some help. How much does these motor weigh the motor is a early 84 with a gen.
Yes, tilting it out to the brake side unless you lay it on it's side as mentioned in other posts. If the bike is totally stripped down laying it on it's side is a good idea, but if it's all together it would be kind of hard with the handlebars, etc. keeping it from laying flat.
Pinion, your back had to be hurting after doing it yourself...I had to have my wife help which was pretty much the same as doing it myself.
Old Oct 7, 2008 | 11:10 PM
piniongear's Avatar
piniongear
Oh, the back did hurt!
OK, I gotta tell the whole story here.
I nailed together 4 pieces of wood (like a picture frame) and nailed a piece of plywood on top of that. Finished, it looked like a box and was the same height off the floor as the top of the frame tubes.
I had to lift the 188 lbs up high enough to get above the frame, then I just moved it sideways on to the box. If I were required to let the engine down to the floor gently (what, another 6 inches?) I would have never made it!
And yes, I had to stand there and think about it for a long time when the engine went back in. That was much more difficult because I did not want to mark the new paint.........pg
Old Oct 8, 2008 | 03:00 PM
98glider's Avatar
98glider
If I lay the bike on its side I should lay her on the primary side and have lots of cushion. Is there going to be any internal damage that can happen/ I will take off the shifter handle bars oil tank battary and drain the oil and trans etc that will be sticking out If I decide not to lean her can take the motor out the brake side and install her the same side I have a picture of the bobber in my gallary Thanks guys I just want a smooth transfer and no motor damage it is hard to find a good ironhead mechanic around, that is why you have to do it yourself.I never got into the motor but I can do other things
pmck7
Sep 20, 2017 09:18 AM
goose1169
Shovelhead
Jun 12, 2013 10:39 PM
1955RigidFrame
Custom Models
Mar 20, 2013 08:00 PM
Metolius
Custom Models
Jun 24, 2009 11:58 AM
wizardry68
Jun 19, 2009 02:57 PM
