Ironhead A place to talk about Ironheads.
checking timing
Old Apr 18, 2009 | 07:47 PM
sugarplum247's Avatar
sugarplum247
ive cleaned the carb it may need sommore adj s&s super B been told its to big for my 1000 cc xlh but dont know for sure
Old Apr 19, 2009 | 08:15 PM
sugarplum247
any comments on installing an electronic ignition is it worth the money or not
Old Apr 19, 2009 | 08:56 PM
IronMick's Avatar
IronMick
This is one of those controversial questions. IMO a very good idea to get a single fire electronic ignition. Easier starting, smoother running, etc. Others will express the opposite point of view.
But be sure you have any carb/fuel related issues solved first.
Old Apr 20, 2009 | 06:58 AM
GA Ironhead's Avatar
GA Ironhead
looks like serial # only other than timing marks ...
A phone call to S&S may be in order, if you're interested in finding out what stroke you have. They may be able to identify your wheels from the numbers that you have. It's worth a try anyway.
Old Apr 20, 2009 | 07:03 AM
GA Ironhead
Some like points, others electronic. Points are mechanical and easy to trouble-shoot. Electronic can give you an infinite number of advance curves. Very dependable until they go TU, at which point they're more difficult to trouble-shoot.
No easy answer to this one. Research and form an opinion. Ultimately, it's personal preference.
Old Apr 20, 2009 | 01:36 PM
gunnut1's Avatar
gunnut1
IN 1971 I Built a Stroker motor (still have it) from a 1970, 4& 5/8 stroke (77 inches), S&S wheels, at that time ALL Sportster S&S wheels had a 40% timing mark (S&S said that was for fuel engines). You timed it at the edge of the window to get 45% for gas ( gas was good then!). If I remember correctly, the timing mark on stock flywheels for all 883s was 45%, will have to look in my service manual to be sure or PINION will correct me I hope. Mine has 11 to 1 compression, never made a sound (detonation) at 45% with the gas back then.
Old Apr 20, 2009 | 05:30 PM
sugarplum247
im going to get the # off crank and find out what i have had it running saturday now she wont i get some smoke out of pipes and a pop out the carb but she just dont want to take off still playing with the carb
Old Apr 20, 2009 | 05:43 PM
t150vej's Avatar
t150vej
Static Timing 101
All this is assumimg your points are good and correctly gapped.
Switch off. Get it at TDC. Loosen the points plate and turn it clockwise until the points JUST START to break. (It's best to use a continuity light or DVOM with an audible signal, a simple ohmmeter will work) Lock it down. Then, if it doesn't fire, look elsewhere for the problem.
Old Apr 20, 2009 | 06:00 PM
sugarplum247
ill give it a try points and condenser are new so i know they are good
AmericanNightmare73
Ironhead
Feb 27, 2012 12:29 AM
nicksorg
Ironhead
46
Jul 2, 2008 02:52 PM
dba1_2000
Aug 27, 2007 09:31 PM
ChrisB
Ironhead
Oct 2, 2006 01:21 AM
copper
Sep 26, 2006 04:22 AM
