Ironhead A place to talk about Ironheads.
idle goes up
Old Nov 28, 2010 | 02:08 PM
98glider's Avatar
98glider
Default idle goes up
I have a early 84 ironhead with a s&s carb the idle goes up when she is warmed up I did check the cables where they enter the carb to see if they are sticking they return and touch the idle screw. I checked the intake for leaks with propane and no change in rpm. Is there anything in the carb could be giving this poblem Thanks for your help.
Old Nov 28, 2010 | 03:24 PM
straydog13's Avatar
straydog13
probably not the answer you want but to me taht is kind of normal.i would just adjust the carb when its warm.
Old Nov 28, 2010 | 04:10 PM
Blackcherry Low's Avatar
Blackcherry Low
I was thinking the same thing, that sounds normal to me. When I start mine I give the idle speed screw a half turn in to help it idle better when doing a cold start. Then after it warms up I have to turn it back down of course. If I didn't turn it in before starting I'm sure it would just barely idle if at all without having to keep dicking with it, so I just start with a fast idle.
Old Nov 28, 2010 | 04:36 PM
98glider's Avatar
98glider
Something sounds funny I start the bike and sounds okay when she is cold and is warm after she gets hot the idle goed up I feather the clutch in gear pull the clutch in and she goes back down. If i am sitting there and give the bike gas let the throttle go the idle is up hard to get it back down the throtle body where the cables connect looks like they are back but I did notice that there is 1 spring on the throttle return(2 cables) where the cable connects maybe not tight enough Thanks
Old Nov 28, 2010 | 08:10 PM
IronMick's Avatar
IronMick
The idle mixture screw [AKA the pilot screw] and the idle speed must be set when the engine is at full operating temperature. Then, when you start the bike cold, you have to work the throttle to keep it idling, but when it warms up it will be correct. This is the way it is supposed to work.
If you set it up when hot, then the idle speed changes as it warms up, the usual cause is intake leaks.
Old Nov 28, 2010 | 08:20 PM
scottfisher's Avatar
scottfisher
"but I did notice that there is 1 spring on the throttle return(2 cables) where the cable connects maybe not tight enough Thanks"
sounds like problem solved.
Old Nov 29, 2010 | 06:20 AM
IronMick's Avatar
IronMick
The return cable has the spring at the carb end of the cable.
Old Nov 29, 2010 | 03:16 PM
98glider's Avatar
98glider
Okay when she is cold your right the bike needs some throttle to keep her goin. As she gets warmed up she is fine after riding around and she gets hot that is where the idle goes up then I adjust it back down then. The bike starts up fine 2 squirts of throttle lift choke half way and she starts right up . Push the enricher back down set the throttle lock screw to keep it goin and that is it,.
Old Nov 29, 2010 | 03:47 PM
peppi's Avatar
peppi
Has it always done this? Is the bike new to you? Have you checked the jetting in the carb? How about the idle mixture setting?
Possibly the cables need lube, could be hanging up a bit.
Old Nov 30, 2010 | 01:56 AM
IronGear's Avatar
IronGear
Well, where to start.
When you say S+S carb, what type?
Assuming that you are not using any form of choke/enrichner after starting, it would seem reasonable that the idle would be a little higher when the engine reaches operating temperature, especially if you have set the speed initially when the engine was a little cold still.
Are you saying there is an external return spring? Or are you referring to the small spring on the return cable itself, which has nothing to do with throttle return?
If there is some butterfly shaft wear, you can certainly get an undesirable idle speed variation.
A worn mechanical advance unit is a likely place for increased idle symptoms as well.
