Ironhead A place to talk about Ironheads.
Weird Oil loss "schedule"
Old Sep 25, 2012 | 02:16 PM
Krazyshark's Avatar
Krazyshark
Default Weird Oil loss "schedule"
So oil loss is not new to me, I was replacing a qt of 70wt about every 500-750 miles. Not perfect but it gets me around, still cheaper than my car and 1000 times more fun!
Anyways I have noticed a weird pattern over the last 1200 or so miles, I will have full oil after topping off for a good 250-300 miles, almost no change at all. All the sudden, it happens at the 320-330 mile mark on the full oil tank, I will lose 1-1.25 quarts in what seems like one ride.
When I changed the primary fluid 600 miles ago it was not over filled, it was 21 oz that came out. My oil leaks around the cylinder bases, where the tappet block meets the pushrod tubes, near the genny, and mostly at the rear sprocket (which as a plus keeps my chain nice and lubed! though my rear rim looks cruddy). I don't believe my engine is sumping, or else there would prob be 3 qts too much oil in it from me topping off.
Its just weird that in the span off 20-30 miles I would lose so much oil, but not lose any before the large loss. Any insights?
Old Sep 25, 2012 | 05:03 PM
IronMick's Avatar
IronMick
What year is your bike?
If you have a 79-85 with the crankcase vent going into the back of the air cleaner it could be sumping and then just burning it up.
Old Sep 25, 2012 | 11:59 PM
Krazyshark's Avatar
Krazyshark
Its a '78, nothing run to the air cleaner on mine. I would have a perfect explanation if I steadily lost oil, resulting in filling a quart every 300-500 miles or so, its just the fact that it seems to have a full bag until, then will all the sudden lose a lot after 320ish miles is weird. I am topping off tomorrow before I ride to work and see if I can't get any more details. Going back down to 50wt this weekend, we'll see if that changes anything as well.
Old Sep 26, 2012 | 06:42 AM
IronMick's Avatar
IronMick
Do you have the in-tank oil filter? in-tank dip stick? do you remove the filter to check the oil level? I have both the in-tank filter and dip stick in my '78 XLH. I cannot trust the dip stick - i think oil stays up in the filter; one time i ran the oil quite low before i realized what was happening - so i remove the filter to check the oil and keep the oil at the level of the bottom of the flange for the vent line fitting.
It is common to use 60W or 70W in very hot climates. Most of us use 50W.
Old Sep 26, 2012 | 12:39 PM
Krazyshark's Avatar
Krazyshark
My 78 has the same setup, dipstick, filter "cup" and filter are in the tank. I check the dipstick with the whole assembly in place, but fill it without the dipstick filter assembly and the oil is still low. The filter seems to hold some oil, but I doubt its more than 3-4oz.
My indie recommended running 70wt in the ironhead and 50wt in the winter, dead set against ironheads running 20w50 which I did last winter. I know this is a hot topic, but I trust my indie (been around since the 60's in the same location) so I generally follow his advice first.
Old Sep 26, 2012 | 04:21 PM
IronMick's Avatar
IronMick
I run 50W in the late spring, summer, and early fall; then 20W50 in winter. Last year i put the 20W50 in too soon - i will not do that again - too much engine noise!
I no longer check the oil level with the filter in place because i found it unreliable - it showed sufficient oil when the oil was low. I wonder if this is happening with yours?
I had to trim some off the end of the dipstick to accomodate the newer style in-tank filters ...
Old Sep 26, 2012 | 04:40 PM
Shredding rubber's Avatar
Shredding rubber
Engine noise with 20w-50,must have been mobil 1. Royal purple automotive 20w-50 kept my cammed 106 nice and quiet,as does motul. Straight 60 from Amsoil is my new summer oil,my bike ran noticeably better with it in the sump.
And if this guys bike is drinking straight 70 grade then 20w-50 won't stand a chance.
Op. That is a very bizarre consumption issue. I guess unless you want to take is completely apart I guess just keep your eye on it and keep adding oil.
I suppose on the plus side you would never have to change your oil,just the filter due to constant top ups.
Old Sep 26, 2012 | 06:32 PM
IronMick's Avatar
IronMick
To add a note to my previous post, taking the filter out can be messy. I lift it up and set it down at an angle so it is above the oil. Then i leave it for whatever time while i do something else giving the oil in the filter time to drain out. Then i lift it out and look in with a small flashlite, hoping to see the oil level close to the bottom of the flange for the vent.
Old Sep 26, 2012 | 07:38 PM
scottfisher's Avatar
scottfisher
Take some time and address these leaks.
The cylinder base--may just need to be tightened (30ft-lbs)
push-rod tube -- new corks
genny -- new gasket (make one from rubber auto gasket paper)
rear sprocket -- new seal and a bit more involved but not difficult
cjshovel
Shovelhead
Apr 26, 2014 03:27 PM
Norb5150
Jul 4, 2013 01:04 AM
truthfire
Apr 4, 2011 02:04 PM
mxz600
Jul 28, 2009 05:29 PM
Towboater07
Aug 20, 2008 12:12 PM
