Ironhead A place to talk about Ironheads.
shifter shaft problem
Old Jul 12, 2014 | 03:14 PM
Ironkidzsled's Avatar
Ironkidzsled
Unhappy shifter shaft problem
I just finished replacing my flywheels/crank/rods assembly and after rejoining the two case halves relized my shifter shaft is not engagin in the pawl carrier.. ! Do I have to seperate again or is there another way to get it back in the right spot?
Old Jul 12, 2014 | 04:49 PM
IronMick's Avatar
IronMick
I am not familiar with the installation details, but i am certain that you do not have to split the cases for that. Some else may be more helpful. What year is the bike?
Old Jul 12, 2014 | 05:09 PM
Ironkidzsled
74 xlch
Old Jul 13, 2014 | 12:00 AM
Ironkidzsled
Not looking too promising... fml
Old Jul 13, 2014 | 08:15 AM
johnjzjz's Avatar
johnjzjz
But you do have to remove the trans again - i do not know how far along you are with that but the shift arm only sits in a pocket in the selector -- we use a majic marker to mark the correct location and that would be at 3 oclock as you look into the trans
hold it at 3 oclock and mark the top of the shaft on the out side of the cases at 12 oclock so once installed you know its in the detent of the shift pawl
Old Jul 13, 2014 | 12:12 PM
Ironkidzsled
Cool thanks! I will try that. Not sure how the hell to get the clutch drum off since the crank sproket and chain are both off the bike
Old Jul 13, 2014 | 12:38 PM
johnjzjz's Avatar
johnjzjz
the clutch hub and the front sprocket with the chain will need to be put on at the same time or it wont happen - you will also need to lift the chains shoe when you install the set up to get it to slide in
you need the books dude parts and service so when you ask a question its not in the incorrect part of the assembly and answers will make sense
Old Jul 14, 2014 | 12:34 AM
Ironkidzsled
In a perfect world.. Or at least one where im not so broke! Lol. Btw I know what your saying about them both going on at the same time since that's the only way it will. The problem is figuring out how to get this damn clutch drum off. Well the nut in the center one to be more specific. Got the outer one where it wont move but the inside one keeps bending the damn sprag or slipping. There's gotta b a better way... Btw appreciate yalls help! And good to hear from ya again mick its been awhile! State of Texas decided to put me in time out for awhile! Lol
Just thought I'd update success removing that clutch hub via. Construction flatbar and the chain tensioner. . Unfortunetly the chain tensioner suffered some injury but I think he will live after some bending/hammering. Now im on to pulling this damn 4 speed tranny to get my shiftrr in the pawl! Any tips are. Appreciated!
Old Jul 14, 2014 | 10:43 PM
Ironkidzsled
Okay now I know got the shifter in the pawl carrier this time but when I try to turn it to shift gear it wont move! Can I adjust how easy it is to shift by loosening the the spring nut on the outside of the transmission?
Status update: Got tranny back in and shifter working so moving onward to do right side oil pump/timing/ cam etc. While I wait on my clutch hub bearing to come in the mail.
Last edited by Ironkidzsled; Jul 15, 2014 at 12:30 PM. Reason: problem with shifter was solved
97EGC
Oct 20, 2016 10:55 AM
89FLHTC
EVO
29
Dec 19, 2015 06:17 PM
PFR-Captain
Jun 5, 2014 02:27 PM
albngore
Jan 10, 2012 08:44 PM
JacktheBagger
Oct 2, 2008 09:21 PM
