M8 problems
Old Jan 24, 2018 | 07:12 PM
  #1181
splattttttt's Avatar
splattttttt
Old Jan 24, 2018 | 08:06 PM
  #1182
Max Headflow's Avatar
Max Headflow
Originally Posted by Roadglider8131518
Picked up a 2018 roadglide sp Friday before labor day 2017, fell in love with it! After around 250- 300 miles noticed bikes smokes on cold startup. The bike now has 955 miles and smokes so bad on cold start up, that fills garage full of smoke. Talked with dealer, mine is not the only one doing this, I also stopped at two other area dealership s , they also have new 2018s doing this. Talked at length with service manager at my dealership, they had a 2018 Street glide apart for same thing, I asked what they found said rings were gapped .010 of an in. too wide. I have been a mechanic for a living for over 32 years and didn't agree with that. I suggested maybe a guide to valve fitment issue or possibly a oil cooling port porosity issue. They tore heads off and checked port which air pressure on a water tank and indeed the casting is porous!! Has any else experienced this?
The porous casting is simply keeping up with tradition..
Old Jan 24, 2018 | 11:23 PM
  #1183
johnnynitro's Avatar
johnnynitro
Some have suggested that is the reason for the Trans to Primary transfer too !?
Old Jan 25, 2018 | 12:08 AM
  #1184
MTBIG G's Avatar
MTBIG G
Little update on my 17 RGU. Love the bike, but toward the end of the summer with only around 3500 miles, it was making more and more noise in the camchest area. Took it in for a checkup. They found the oil pump was working well, the adjustable pushrods were properly adjusted and that everything checked out. So I rode it some more in the fall and the noise just got worse, and at times would lose power. The noise was especially bad at startup after it sat for several days... terrible rattle for about 30 -45 seconds- lifters?. So back to the dealer. Took over a month, but the dealer finally got it figured out.
The main culprit was a bad spring on the cam chain tensioner. Also had 1 tappet going bad. So with a new chain tensioner, and 1 new tappet, everything seems better. At least its nice and quiet on startups. I'll know more as the weather changes.
Anyone else have issues with the cam chain tensioner?
Also had the clutch switch replaced, and still have unresolves primary fluid transfer issues.
Old Jan 27, 2018 | 06:48 PM
  #1185
mjwebb's Avatar
mjwebb
"spring on the cam chain tensioner"...the cam chain tensioner is hydraulic
Old Jan 27, 2018 | 07:48 PM
  #1186
MTBIG G's Avatar
MTBIG G
It also has a spring to take up slack during startup until the oil pressure builds up.
Old Jan 27, 2018 | 08:15 PM
  #1187
Max Headflow
Actually, the small spring helps to push out the shoe when running during the time the shoe is unloaded. The hydraulic setup on a lifter is pretty much the same as a valve lifter. There is some bleed-down. It needs to adjust for run-out on the crank and cam and as the motor heats up.
Old Jan 28, 2018 | 07:55 AM
  #1188
jpooch00's Avatar
jpooch00
Originally Posted by HDSlimJim
Yep, and there you have it....why our children are being sent to die in the desert, or come back physically/mentally blown bits...because the USA is full of ignorant, gullible, ***** sucking up the propaganda that their children, and others, must "sacrifice" for the rest of our "freedoms".
War is now a business, big money being made; and it all comes to a halt if you stop sending your children to die in the name of "freedom"...but you won't, because you're Jane...
Off topic and political, granted, but 100% true!
Old Jan 31, 2018 | 09:06 AM
  #1189
SoCalHDMC's Avatar
SoCalHDMC
Originally Posted by Heatwave
Ok, very interesting turn in this thread, but I also heard that Amsoil can resolve all the M8 issues! LOL!
Had not heard about the Amsoil Fix!!! Currently ordering 277 cases of MCV Synthetic V-Twin oil (I would have ordered more but that is all they had, Amsoil rep said they would step up production in anticipation of a huge sales spike!). Thanks for the intel. 😂
Old Jan 31, 2018 | 11:25 PM
  #1190
Oldman - New Iron's Avatar
Oldman - New Iron
Originally Posted by lyork
Several threads about engines needing replaced? Seriously? Where are all of these threads about engines being replaced? I've seen one to date
My engine started making noise at 8000 miles, first they had to send to get a tool to check oil pressure, week 1, get a call today, it's piston slap, have to wait till next week to get new pistons & cylinders, total b.s.
