M8 problems
Old Oct 31, 2017 | 02:47 PM
  #1081
rjjj629's Avatar
rjjj629
Originally Posted by splattttttt
Now to your question. Compression relief valve. Harley’s don’t have them. And that is often an issue with starting. Don’t matter if it’s warm or cold outside
There was an ACR valve for the twin cams...
on the M8 its p/n 18400073
Just me but I've never seen the HD compression release valve go bad on a twin cam - I've heard about it once or twice but never run into it myself. I have had problems with the HD battery going bad when it gets colder. Ive seen a couple go bad in the cold even if they've been garaged and on a tender every single night... just bad luck of the draw I guess.
Old Oct 31, 2017 | 02:56 PM
  #1082
Never2Late's Avatar
Never2Late
At a M8 workshop l attended at a harley dealer Saturday one of the techs mentioned that MOCO had upped the cold cranking amps on there batteries. They also said the engines were designed to turn over twice before starting in order for the lifters to be pumped up.
Old Oct 31, 2017 | 03:07 PM
  #1083
splattttttt's Avatar
splattttttt
Guessin I should have stated that an ACR valve can be installed. PITA and expensive less you’re a DIY’er
Now on the cold weather amperage bump on the m8 batteries, didn’t know a out that.
Old Oct 31, 2017 | 03:37 PM
  #1084
rjjj629's Avatar
rjjj629
I'm thinking its standard on the M8s - at least my parts manual says its common to all the 2017 tourers.
Old Oct 31, 2017 | 04:33 PM
  #1085
lp's Avatar
lp
You're not wrong...
ACRs have been standard since the introduction of the TC103 as an option (in 2011).
The TC103 which became standard in 2012, the HO103 (2014), and M8 (2017) also have them standard.
OP's problem sounds like a weak battery. Normally shows up in cold conditions.
Old Oct 31, 2017 | 04:44 PM
  #1086
QNman's Avatar
QNman
Originally Posted by lp
You're not wrong...
One point of order... my 2010 Limited had the 103 with ACR's.
Old Oct 31, 2017 | 06:10 PM
  #1087
splattttttt
Wish I’da known bout the ACR’s bein optional in 2014. Didn’t do my homework, so my fault.
My bike will occasionally lock up during starts. And than bags hard pryor to ignition. Scary
Old Oct 31, 2017 | 09:58 PM
  #1088
lp's Avatar
lp
Good catch. Yep forgot those. First year for the "Limited" and the TC103. Back when the Limited was more... well unique and more like a CVO Jr.
Basically, for the standard/limited bikes, ACRs were introduced with the TC103.
CVO's had them since 2007 with the introduction of the 110 but not in the CVO103 in years past - probably because of the shorter stroke.
Old Nov 1, 2017 | 08:40 AM
  #1089
Max Headflow's Avatar
Max Headflow
Not an expert on CVOs but the early pre-2007 CVOs had same 4 3/8 stroke as the current twincams.. IIRC they ran the CVO head which was 90 to 92 ccs to get the cr lower. I think they did use the SE255 cam but could be wrong.
Old Nov 2, 2017 | 06:37 AM
  #1090
lp's Avatar
lp
Yeah, you're right. I remember there being some difference and I was thinking about thinking the 88/95 crank for some reason.
In 07 they basically put a variation of the CVO103 crank into the TC96.
I'm not sure what cam came with the CVO103, it was small ended though (small bearing).
