M8 problems
Old Jan 28, 2021 | 05:18 PM
  #2051
Redrodyankneck's Avatar
Redrodyankneck
If bike is tuned properly and use good oil (Amsoil for me lowered temps 10deg before) I think this motor will be really happy.
Now he's gone and done it!!
Old Jan 28, 2021 | 05:49 PM
  #2052
mjwebb's Avatar
mjwebb
Originally Posted by Burbur2
If I would ever consider stage 3 I would upgrade to cam-plate and fueling or S&S pump but for stage 2 I dont feel throwing extra 500$ is needed. It is proven that 2020 pump is good unit and helps with issues of sumping which is main reason we upgrade it.
From what I researched one good advantage of fueling and ss units is that they create a lot of flow which in turn help with way better cooling in the process. Some said temp drops up to 20 degrees which I consider a lot due to more laminar flows due to high quality manufacturing tolerances comparing to stock castings which needless to say is more $$$ efficient for MoCo. This temp drop would be one and only reason I would even think to do this upgrade at stage 2 but is it worth it 500$ extra to have a bit cooler engine - not sure about that part.
I am not an expert of any kind but this is what I found out while watching few videos on YT - mainly Baxter garage dude. He is smart and make a lot of sense.
guess we don't know what "some said" or "way better cooling" translates to in reality...and Amsoil 10 degrees cooler oil temp claim..sure, ok...well if all that is true everybody should run out and buy up all that stuff! and with the HD Fan assist oil cooler which does lower oil temps up to 50 degrees, well heck it'll be like a snow cone machine inside the engine!!!
Old Jan 28, 2021 | 06:11 PM
  #2053
Burbur2's Avatar
Burbur2
I dont care if you guys believe me or not. In the past I had hot rodded 1994 Sportster that at some point was really sensitive to temperature due to high compression ratio. I tried many oils and Amsoil was the only one that got the job done and made a difference which allow me to avoid detonation. You dont want to believe it I dont really care I know what I experienced.
Old Jan 28, 2021 | 06:58 PM
  #2054
Jeff1759's Avatar
Jeff1759
Originally Posted by mjwebb
because they might really really be into supporting small business over large corporations....but seriously, this is one example where 'settling' for the HD part makes sense because of its track record and low cost..I think most will agree
Good advise and I thank you for it.
I feel there is a lead mechanic at this shop who likes to push high performance parts...probably his personal preference, and that is appreciated, but I cannot really afford the high end stuff, nor do I have the need to blast down the strip or tear **** up.
Just want assurance I can own and ride a quality product, made in the USA, that won't crap out on me when I need it.
Old Jan 29, 2021 | 02:28 AM
  #2055
DTTJGlide's Avatar
DTTJGlide
If you haven't had a problem in 2+ years I don't know why you're trying to fix something that's not broken.
Old Jan 29, 2021 | 06:07 AM
  #2056
Jeff1759's Avatar
Jeff1759
Good point. I haven't really ridden it far or hard. I'm retired now and plan on taking some long trips. I guess hearing all the bad stories about sumping have got to me, in that I can't be sure that it still might, or might not, happen...
I've got 10,500 miles on it. While there is logic in the fact that it hasn't happened yet, so there is no need to fix something that isn't broken, I can't stop the nagging thought that it could still happen.
Haven't been an avid follower of the sumping issue threads, but are there cases where's it has occurred after 10,000 miles?
Old Jan 29, 2021 | 05:44 PM
  #2057
Redrodyankneck
When the M8 was released sumping was more common with riders that use their bikes in the higher RPM range, that's why stage3 and 4 were having issues originally. "Disclamer" I did say more common on S3 &4 but have read where some owners reported sumping on stock bikes. The cam HD S3&4 comes on in the mid to upper range so these guys ride the bikes harder than you. I had a 2017 SGS with stage 1 and rode it 21,000 miles without any concerns or symptoms of sumping. In a trip to the mountains two up, we rode a for 10 days 8 hours per day straight, keeping the RPM's above 3500 for hours of up and down steep inclines, then hitting the highway back to camp 70-80 mph. This was during the summer 80-90 degree days and no problems,
If you are really worried, push your bike hard with high rpm's on back roads or hills for several hours then hit the highway doing 70-80 mph.. It will be good for your confidence and a good time to blow the carbon out of that motor of yours.
Old Jan 29, 2021 | 07:00 PM
  #2058
Jeff1759's Avatar
Jeff1759
Thanks Redrod.
Old Jan 30, 2021 | 07:54 AM
  #2059
Keithhu's Avatar
Keithhu
This was not is any way the case when I had 3 stock 107 engines replaced under warranty. Not sure how this mythology of only bikes "ridden hard" (not that any scenarios you describe can be called hard IMHO) had problems.
Old Apr 15, 2021 | 09:39 AM
  #2060
Peter Quinn's Avatar
Peter Quinn
My Doctor says you don't really have any problem, until you stop breathing. Keep worrying about anything else and youre sure to stop breathing!
