M8 problems
Old Apr 17, 2022 | 09:53 AM
  #2111
1melted1's Avatar
1melted1
6th Gear
Default 2018 M8 coolant issues
Morning,
please forgive me if this is not the place to ask this question and if it's not could someone please direct me. Thanks in advance.
Where's the problem?
2018 road glide ultra M8 from cold it will run for a short distance and overheat. Looked at the overflow jug inside the lowers and it was at the proper line before driving but once it got going, it filled the overflow jug to the top. Stopped and shut bike off then started water pump manually. The level dropped. Ran bike again and same things happened. Checked the pump and it does run. Checked the cap and its on properly. No obvious signs of leaking. Any suggestions?
thanks again
Steve C
Old Apr 17, 2022 | 10:06 AM
  #2112
Quik's Avatar
Quik
Originally Posted by 1melted1
Morning,
thanks again
Steve C
Is your motor laboring more than usual? Maybe pull the crank position sensor with the bike upright and see if you have excess oil in there.
Old Apr 17, 2022 | 10:22 AM
  #2113
1melted1's Avatar
1melted1
6th Gear
The bike seems to run fine, no idle issues or starting problems. I'll have to look for the position sensor and see about checking there.
thanks
Old Apr 17, 2022 | 10:35 AM
  #2114
Quik's Avatar
Quik
thanks
Very simple check, 3/16 Allen bolt and just pull the sensor out, I would put a pan under it incase there is a lot of oil in the crank
Old Apr 17, 2022 | 10:45 AM
  #2115
smitty901's Avatar
smitty901
Go ahead and check for the sumping by pulling Crank senor. It hurts nothing to do so. This however sound like a water pump issue. Do the self test for fan and pump. Bet it is the pump. or fans
Old Apr 17, 2022 | 10:52 AM
  #2116
Rounders's Avatar
Rounders
I hope M8s are different than TC, that would be a lot of oil.
I read somewhere with TCs, to pull the drain plug on bottom end and measure oil to see if sumpin. Can you do that with M8s?
Old Apr 17, 2022 | 11:08 AM
  #2117
1melted1's Avatar
1melted1
6th Gear
I'll try pulling the sensor for the crank. The fans and pump are working.
thanks again
Old Apr 17, 2022 | 11:09 AM
  #2118
Quik's Avatar
Quik
Thats what I mean when I said pull the crank position sensor, I drained 60 ounces out of my crank when my bike sumped.
Old Apr 17, 2022 | 11:19 AM
  #2119
Rounders's Avatar
Rounders
TCs have a plug on the bottom. You can drain the oil and measure. 60 ounces is crazy
I am thinking of updating one of these years. I don't want to be a dinosaur. But one of my buddies says he has oil in exhaust, but doesn't care because it has a warranty. Myself I keep for years.
But the rest of it, and new stuff I want. Just the better saddlebags.
Old Apr 17, 2022 | 11:28 AM
  #2120
Quik's Avatar
Quik
Yeah when that 60 ounces was in there the bike was laboring so bad it would barley pull itself, luckily I was only a couple miles from home. It sumped all of that after a 1st through 5th redline run through the gears, I knew immediately when I pulled out from the stop sign after that run what was going on, felt like wide open throttle with the brakes applied.
