M8 problems
Old Apr 17, 2022 | 11:30 AM
  #2121
Adirondack Bob's Avatar
Adirondack Bob
Default How To Pull Crank Case Sensor and more
Ron has several videos on all issues related to the bad oil pump, pre May 22, 2019. I'll be replacing mine soon, just to avoid this issue from causing damage to engine parts. Warranty work won't replace all damaged parts. Good luck!
Old Apr 17, 2022 | 11:34 AM
  #2122
Adirondack Bob
Originally Posted by Quik
Thats what I mean when I said pull the crank position sensor, I drained 60 ounces out of my crank when my bike sumped.
What did you do to fix the problem! TY!
Old Apr 17, 2022 | 11:43 AM
  #2123
Quik's Avatar
Quik
My bike is an early 2019 cvo that did not get the new oil pump and seal, actually the new 8 lobe pump was not even put when this happened but HD put a new cam plate with the seal in under warranty and left the same pump in because at the time it was the newest one out. The seal solved any further sumping. My bike is now a FM 128 and I had them put in the newest 8 lobe pump when it was built, zero sumping for me since the seal was put in.
Old Apr 17, 2022 | 11:46 AM
  #2124
Adirondack Bob
So, the new cam plate, and seal, took care of it by itself? I didn't know the cam plate was missing a seal, like the oil pump. TY!
Old Apr 17, 2022 | 11:47 AM
  #2125
Rounders's Avatar
Rounders
But why? Why add a vent to the primary now, after all these years? Running hot becuase of emmissions?
Old Apr 17, 2022 | 11:58 AM
  #2126
Quik's Avatar
Quik
Not really sure why they replaced the cam plate but the pump seal took care of any further sumping for my bike. I actually tried to make it sump after the warranty work and it never did and has not since. Hours and hours of 85mph interstate through multiple states, banging through the gears to redline and all has been good, actually great now with the 128, should have done that sooner! LoL
Old Apr 17, 2022 | 04:29 PM
  #2127
SMR65's Avatar
SMR65
Old Aug 29, 2022 | 08:01 PM
  #2128
Bible44840's Avatar
Bible44840
3rd Gear
Default Turn Signal an faring tracer lights blink opposite.
Having a issue with faring tracer lights blinking opposite of the turn signals. The tracer lights are a plug n play. Anyone have a solution to fix this ?
Old Aug 29, 2022 | 11:35 PM
  #2129
johndoe297's Avatar
johndoe297
Probably need to sync the new lights. Here is the procedure:
Old Feb 3, 2023 | 08:52 AM
  #2130
Peter Quinn's Avatar
Peter Quinn
I hear some well posted company is coming out with new rockers to correct the defective ones in the M8. And another well known company is building two stabilizers one for the front one for the rear to correct the death wobble.
When will some engineer from the factory take action? The wobble is coming from the loose swingarm.The shaft is machined undersized for the ID of the Spherical bearings.Take out the shaft.Have it hard chromed and precision ground to press fit the bearings. Wobble Gone!
