Milwaukee 8 Build... Experienced input?!?
Old Sep 25, 2016 | 08:23 PM
PadreJuan's Avatar
PadreJuan
Stage II
Default Milwaukee 8 Build... Experienced input?!?
Looking for feedback from a bit broader audiance than just my local dealer mechanics... Since this is a new motor, builds are naturally new territory for many.
2017 Street Glide 107 doing SE Stage 3 with; SE ProStreet Tuner, SE 10mm Plug Wires, SE Perf. High Comp. Plugs, Thunderheader 2:1 Exhaust.
AND I'm leaning toward doing the TimkenBearing and also the SE 58mm EFI Throttle Body (re-using stock injectors for now) and the SE Heavy Breather Air Cleaner.
Mechanic agrees on both upgrades (TB & 58mm) but no one seems to have any concrete performance numbers / expectations with such a setup other than the factory Stage 3 numbers.
Anyone out there done such a build? 58mm help any? Any feedback? Pros Cons?
PadreJuan
Old Sep 25, 2016 | 08:29 PM
Prot's Avatar
Prot
I think you would do well by looking at what Fuel Moto is doing.
Old Sep 25, 2016 | 08:43 PM
roadrash3's Avatar
roadrash3
PadreJuan
Confused by a few of the things, as i am doing a stage 3 right now. I am not aware of thunder header having an exhaust that fits this new motor, and as far as the timken bearing or the SEperf. High comp, is any of that necessary as again its a new motor, with different unknown parts. I would recommend doing a dyno with this kind of build, not just the harley tuner, but you also realize you throw out the new warranty, the moment you do most of this except the stage 3. I don't think anyone would know any numbers as no one is to this point yet because there is no exhaust yet. I second the other comment that i would look towards fuel moto as they are posting the most information on this stuff right now. just my 2 cents, good luck and keep us updated.
Old Sep 26, 2016 | 09:20 AM
PadreJuan's Avatar
PadreJuan
Stage II
CLARIFICATION: I failed to specify (sorry), the entire build is being done at time of bike delivery (patiently waiting on parts availability). My dealer has assured me that they will warranty the entire build (including the 58mm upgrade) so that's why I'm going the SE parts route (rather than Fuel Moto or the others).
I learned that the Plug Wire & SE Perf Plugs (High Compression) are "necessary" on another build (2014 SG 103" w/ Stage 4 and they proved to add on dyno numbers - And mechanic agrees that they will prove similar on this motor build.
As for the ThinderHeader exhaust, it's supposed to be available by end of October. (?!? Will see)
PadreJusn
Old Sep 26, 2016 | 09:31 AM
jgrohio's Avatar
jgrohio
PadreJusn
If you use the Thunder Header I dont think your dealer can tell you it will not void warranty, he can promise that he as a dealer wont use it against you, but that doesnt mean it hasnt voided the warranty say you are forced to another dealer while on the road. JMHO
Old Sep 26, 2016 | 10:04 AM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
PadreJuan
Few things are wrong in your list of parts
10mm wires are a waste of money on a M8, not needed on dual plug heads
SE High Comp. Plugs again a waste of money on a M8
There is No 58 mm throttle body for the M8, stock is 55
Here are a few dyno runs on just the stage III build with
Street Cannon 4.5" Slip-on mufflers
High Flow AC
Stage III kit
Tuned with Mastertune2
Attached Thumbnails Milwaukee 8 Build... Experienced input?!?-2017-stage-iii-107-to-114.png
Old Sep 26, 2016 | 01:22 PM
GlidingJoe's Avatar
GlidingJoe
High Flow AC
Stage III kit
You beat me to it, I was about to share the same info about wires/plugs and TB. If his dealer is telling him they are waiting on these parts, he will be waiting a very long time for this build to happen.
Old Sep 26, 2016 | 02:35 PM
riknbeth's Avatar
riknbeth
High Flow AC
Stage III kit
Man that curve looks really flat (really good). I am no expert, isn't it unusual for an HD motor to have such a flat curve?
Old Sep 30, 2016 | 06:29 PM
lh4x4's Avatar
lh4x4
After 3,500 miles I came up with one disappointment. In all the literature, press releases and MC magazine articles that I have read said the oil in the breather was resolved with routing crankcase to the oil pan around the trans.
My SE breather was turning black with road dust and crushed bugs. When I took it off the butterfly valve, intake, intake backing plate and filter were dripping with oil. The vent tubes coming off of the hollow securing bolts were dripping frothing oil.
Crap! Same old same old crap.
Just another breather to reroute the blow by. I have an idea already to mod it.
Old Sep 30, 2016 | 08:52 PM
riknbeth's Avatar
riknbeth
Not good. I am about to put a SE breather on my bike. Will bring this up with my tech. Not going to install unless I understand what is going on.
