Harleys fan-assisted-oil-cooler-kit
Old Jun 29, 2017 | 09:52 PM
CheefASRC's Avatar
CheefASRC
Originally Posted by mjwebb
your engines have always run cooler with Amsoil in the primary and trans?
yes indeed engine cooler, transmission smoother. Next Q?
Old Jun 29, 2017 | 11:46 PM
mjwebb's Avatar
mjwebb
nope, you answered it..using Amsoil in your trans and primary reduced your engine temps by whatever validation you performed to draw that conclusion..10-4, thanks
Old Jun 30, 2017 | 01:37 PM
SWThomas's Avatar
SWThomas
Did you use an actual temperature sensing device? Or just placebo *** gauge?
Old Jun 30, 2017 | 03:52 PM
lp's Avatar
lp
Funny, Magic oil and oil cooler Fans are both tested, certified, and justified by the same test tools and methods.
Combine them both with a pinch of slick-50 and your engine will run as cool as a freezer and live forever and ever and for the evers forever ever. FACT BIYCHES!
Old Jul 7, 2017 | 04:34 PM
Jon Baron's Avatar
Jon Baron
2nd Gear
Does any one know can I use this oil cooler fan if I'm running the thundermax! Please help!
Old Jul 7, 2017 | 05:44 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
As stated in your other thread, your SOL unless Thundermax can handle it for you. It's built into the factory ECM for control and that now gone for you.
Old Jul 7, 2017 | 05:51 PM
Teufelhunden's Avatar
Teufelhunden
Might be able to wire it for manual control on an accessory switch....
YMMV
Lon
Old Jul 13, 2017 | 01:35 PM
squiggyreck's Avatar
squiggyreck
6th Gear
Does anyone have the Oil Cooler Fan and a FP3?
I was hoping you could share your FP3 map, so I don't have to pay the dealer to enable the fan with the Digital Tech computer.
If that will even work????
Old Jul 13, 2017 | 03:04 PM
Drodrigueznyc's Avatar
Drodrigueznyc
wont work.. can only be enabled via the Digital Tech Computer.. I have both FP3 and SEPST. Also, bear in mind that if you do flash a new map to the ECM you might overide the newly enabled fan. Depends on the map being loaded. By default that setting is disabled from the factory. I have flashed new maps a few times and have had to go back to HD to re-enable the fan option via digital tech. So check that the fan is working immediately after flashing anything.
Old Jul 13, 2017 | 03:23 PM
squiggyreck
6th Gear
OK, that stinks...Thanks for the info.
