primary oil level ?
My 2017 RGS is no different than my 2004 Road King, same three holes, same PITA oil service....lol. Of course, its not as bad as a KTM 990, which is a full blown nightmare to change.
On the two HD forums I read, there are many reported cases of the transmission transferring oil to the primary. The how is known. There's only one path between the two, but know one has found out the why.... yet? There are only a few differences between a twin cam trans and an M8 trans... the cause has to be due to one of those changes...
The MoCo is aware of it, but not saying much because a cause/fix have not yet been identified. A couple people have been given new transmissions by the MoCo for this issue, probably so the MoCo can tear into them and find the cause.. It is not something the MoCo is talking about......
Steve Cole can cause the transfer at will, on a couple bikes he has.... he first noticed it during Dyno testing when a trans was making noise because it was almost empty of fluid....
It transfers more oil at higher RPMs, so many, who stay below 3500 rpm, may have it and not even know it....
Again, believe what you will... but the problem exists. I suspect we are close to a cause/fix, time will tell...
The MoCo has been telling dealers who report it, to fill both to the proper level and check again in 1K miles. A couple dealers have used dye in the trans fluid, and then found the dye in the primary... that's how they confirmed the transfer..
The transfer appears linked to rpm, not load, so someone who stays under 3500K may not notice if they had the problem.
Some have reported riding aggressively to see if their's will transfer, and it has not... so it doesn't appear to be all bikes...
I have never said it is not happening. I have added UV trace to mine and check it every 100 miles. 850 into to the test with UV trace and no transfer yet. We will see how it plays out.
I have noticed the narrow primary has thrown a few off a bit. They missed that with the larger opening. In the past from my 07,11,and 13 until the 2016 Had a spot I parked it on side stand filled it just to the edge of the lip stood it up level was prefect. That did not work with the 2016 or 17 with narrow primary.
2011 for trans at first they said 1 quart then changed it to 28oz and check.
