Primary fluid filling?
Old Jun 28, 2013 | 09:55 AM
Scottyrr's Avatar
Scottyrr
Default Primary fluid filling?
I changed the primary fluid on my 13 SG with it on the jiffy stand. The book says to fill it with the bike upright. I was able to fill it with the recommended amount of oil without spillage. Does anyone see a problem with this or has anyone done it this way?
Old Jun 28, 2013 | 10:13 AM
cayers's Avatar
cayers
You should be good to go!
Old Jun 28, 2013 | 10:24 AM
TNCarters's Avatar
TNCarters
That should be fine, I do the same except place a board under my jiffy stand to get more vertical. Don't use the fancy HD funnel, I just put a small funnel into the edge between clutch and primary cover.
Old Jun 28, 2013 | 10:30 AM
omaho5's Avatar
omaho5
If you are draining it through the bottom plug and just removing the derby cover, then you only need to put in 38 oz. Remember this.
Old Jun 28, 2013 | 10:36 AM
DPete's Avatar
DPete
That's how I do it
ron1026
Milwaukee Eight (M8)
17
Jul 11, 2017 08:23 PM
fwb35
Jun 1, 2015 10:55 PM
RZA
Jan 26, 2012 05:22 AM
08bluepearl
Aug 18, 2009 10:34 PM
Gary7
Feb 22, 2009 02:06 PM
