Which cam
Old Aug 26, 2017 | 10:05 PM
rdwild's Avatar
rdwild
5th Gear
Default Which cam
M8 stage IV, HD SE8-515 cam. Bottom end (below 3k) sucks. Between these, what cam would you go with and why? TTS-200 (TTS), WM8-222 (Woods), WM8-777 (Woods)? Has anyone heard the Woods cams in a M8? Are they annoyingly loud?
Old Aug 26, 2017 | 10:49 PM
cmashark's Avatar
cmashark
Are you installing it yourself? If not, talk to your builder. See what he/she recommends.
Old Aug 26, 2017 | 11:33 PM
rdwild's Avatar
rdwild
5th Gear
yeah, installing and tuning myself. TTS tuner.
Old Aug 27, 2017 | 07:29 AM
Tn.Heritage's Avatar
Tn.Heritage
Good luck with the tune but I'd go Woods 222 or check out TTS's cam, lot's of low end TQ on that one as well.
Old Aug 27, 2017 | 09:21 AM
Peter Goodes's Avatar
Peter Goodes
Cycle Rama 460. Check out Sheffer performance. The results speak for themselves.
Old Aug 28, 2017 | 09:19 PM
cmashark's Avatar
cmashark
Stage 4 is 11:1 compression. I would probably go with Wood's 999.
Old Aug 28, 2017 | 09:26 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
https://www.hdforums.com/forum/the-d...l#post16220950
Post #182 and you can see the TTS 200 results. While the total HP is good it is the average Torque that it produces that knocks it out.
Old Oct 19, 2017 | 08:02 PM
Wmoor004's Avatar
Wmoor004
So, the cam is not ideal for use in the 17' M8 with 114 kit? Thank you for your assistance.
Old Oct 19, 2017 | 08:09 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Its great in the Stage III or IV 114 kits! In the Stage III kit application it does require valve springs. It will not fit in the 2018 114 stock engines without valve springs and piston clearance. It does give up a little HP (~3)above 5500 RPM to other cams but none of them can match the Torque output from idle to 5500! So if your looking for the high RPM HP output it may not be what your looking for.
Old Oct 19, 2017 | 08:29 PM
Wmitz's Avatar
Wmitz
Woods/Fuel Moto has a new cam coming out soon for stock comp motors, wm8 22x, I believe. Just another option.
