The Dyno RoomA special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
Just a little update on the TTS 120 Kit with the TTS 200 camshaft. Bike has about 1500 miles on it now, here is the current dyno run. Looks like it may need a little more tuning on the high RPM as we have picked up a little ping above 5500, but we will wait until we get done with the testing. Then a change to the TTS 250 camshaft and see how well it does.
A Stage I kit is Air Cleaner and Slip-ons for the 2017 M8 engine package. What dyno chart are you looking for? If it's not here I most likely have a few I can post up for you.
just curious on combinations that performed the best. I have a road king special 107 and am trying to decide if its worth the money to get header pipes on top of slip ons, heavy breather, and tune.
and if so which brands have you seen perform the best. Fuelmoto has posted pretty easily read information.
I like the open sound of the jackpot slash downs or v&h twin slash rounds.
thanks for any help/ knowledge you can send my way.
So far of all the reports I have been given and what we have tested here the stage 1 of just slipons and air filter are all the same. Sure there are some BS dyno reports out about bigger gains but no one in the field is able to repeat them. The Stage 1 107's are all seeing about 3 hp max increase. That said pick what you like based on looks and sound but you need to hear them in person as video's have proven to mislead many on what they thought versus what they got.
Is it worth putting money into the head pipes or are the gains also minimal?
All depends on what you plan to do with it. For my money if you are going to keep the engine stock then a set of slipons by themselves or an air cleaner by itself is a waste of time, for performance on a 107 M8. The two together with a good tune you will feel a change. Adding a headpipe without cat is a waste of money on and otherwise stock bike. What I can say is how you add parts makes thing look different to some. What I mean is if you add slipons you will see little gain if any and if you add just an air cleaner you get the same results. Now when you add both you will get somewhere. The order you do it in doesn't matter as it takes both to do any good. So if you do AC first then slipons you would feel the gain after the slipons were installed and feel that was the one that did it. Now if you reverse the order and do the slipons first then AC you would claim the AC did the trick.
If you plan to add a cam or more engine parts I will give you a different answer. The headpipe with cat is much much better than HD has done in the past.
sorry I should have been more specific. I would do slip ons, breather and tune. And possibly head pipes of it was worth the effort. No engine mods at this time. Basically wondering if certain slip on breather combinations performed better than others. Thanks for the info up to this point. Has been helpful.
Slipons, Air cleaner = ~ 3hp
Slipons, AirCleaner and good tune = ~6hp
There are people on this site claiming 9 - 12% from just an Air Cleaner and that is total BS on a M8. Uncontrolled or just being flat-out stupid in test methods is the only way I can see to get those type results. Same goes for those claiming 10 Hp from slipons and air cleaner for the 107 M8
