Interesting Problem
Old Sep 22, 2017 | 09:01 AM
DaddyKnuck's Avatar
DaddyKnuck
Originally Posted by stixvrad
Never heard of it before.Maybe a lifter momentarily bled down? That would explain loss of power and the clattering noise. Then it's sudden going back to normal.
I didn't know that could happen. Now that you mention it, the noise was similar to that made years ago when I replaced the tensioners in my Twin Cam. It rattled like it was coming apart while the lifters were getting pumped up.
Old Sep 22, 2017 | 09:44 AM
stixvrad's Avatar
stixvrad
Yeah, the hydraulic lifters have a bleeder in them, that if stuck open could prevent the cavity from filling up inside.Hence causing both valve's( since each pair of intakes or exhaust valves are operated by one lifter) to hardly open. It would make a sh*tload of racket from the right side of the bike.
Old Sep 22, 2017 | 09:54 AM
DaddyKnuck's Avatar
DaddyKnuck
I'm surprised that it could happen to a bike running a running at 2000 rpm, and then refill itself. Hopefully the tech's at the dealer can figure it out, if it's something that is going to be figured out in the short term. If not, I'll have it on record.
Old Sep 22, 2017 | 10:05 AM
stixvrad's Avatar
stixvrad
The other possibility is a plug wire too like the other guy had ( one who had it pull off the plug and another that had it broken and arcing to ground) .That's more of a "snapping" noise but would certainly explain the power loss for sure.
Old Sep 22, 2017 | 04:30 PM
DaddyKnuck's Avatar
DaddyKnuck
The dealer couldn't duplicate the problem, and with no codes it's still a mystery. Good news, I don't have an excessive blow-by problem, I have a cracked breather hose. Bad news is that they have to order it, so I have another 178 mile round trip next week.
gaugeforever
2018+ Softail Models
Jul 8, 2019 11:48 AM
franko3219
Milwaukee Eight (M8)
22
May 22, 2019 07:57 PM
streetglide clyde
2014-2024 Touring Models
Mar 29, 2014 09:11 PM
Geezr Glidr
May 8, 2010 07:33 AM
lewain
Aug 16, 2009 08:34 PM
