battery "tender" recommendations
Old Oct 11, 2017 | 04:44 AM
  #31
Manninagh's Avatar
Manninagh
Optimate 4. It works, it won't over-charge the battery, it will desulphate and restore an excessively discharged battery, and it won't run a current at all if you get the polarity wrong on your connection, which is useful if an idiot installed the pigtail or if you use clips straight on the battery post.
Old Oct 11, 2017 | 05:41 AM
  #32
jgos929's Avatar
jgos929
Battery tender does the same thing for less than half the price
Old Oct 11, 2017 | 11:15 AM
  #33
jcarruth's Avatar
jcarruth
What I use. Cheap and good. BMW MOA rate this one first place several years ago.
https://www.farmandfleet.com/product...yABEgKrF_D_BwE
Old Oct 11, 2017 | 06:41 PM
  #34
talkingrock's Avatar
talkingrock
Deltron tenders are what I use if it's not running it's hooked up to a tender , my last bike was 7yrs. Old and still on the original battery with no issues
Old Oct 11, 2017 | 07:20 PM
  #35
YPD485's Avatar
YPD485
Better keep an eye on the charging voltage of that one. I had the exact one a couple years ago and it would raise the charging voltage to 17 volts. Not good for any type of 12 volt battery. I threw the thing in the trash.
But hopefully it was just faulty.
Old Oct 11, 2017 | 09:14 PM
  #36
FurryOne's Avatar
FurryOne
I've just started working on this spreadsheet, but it should list quite a few of the more popular battery chargers/maintainers on the market. As I get the time I'll add more. Let me know if there's any mistakes - the little buggers do tend to creep in...
File Type: xls
Old Oct 12, 2017 | 06:54 AM
  #37
dDavid's Avatar
dDavid
Doesn't the Battery Tender website discuss temperature compensation? I thousght they compensated.
Old Oct 12, 2017 | 07:25 AM
  #38
FurryOne's Avatar
FurryOne
If they do they're hiding that fact pretty well in their documentation.
Old Oct 12, 2017 | 07:49 AM
  #39
ntg433's Avatar
ntg433
Originally Posted by sn95bullitt
Battery tender makes them for H-D. Harley - Davidson has a 12 month warranty compared to battery tenders 5 years
Nope. They have a five year manufacturers warranty, look in the P&A catalog. This is for the 750 ma model. The weather resistant models have 2 & 3 year warranties. I know because my last one started to overheat just after 4 years. I returned it to the dealer and was given a brand new one. But I do agree it's better to save the money and get the manufacturers one. WalMart has them sometimes a little cheaper.
Old Oct 12, 2017 | 08:40 AM
  #40
teedoff65's Avatar
teedoff65
Yup.
Code:
WATER RESISTANT No
OUTPUT VOLTAGE 12.0 Volt
OUTPUT CURRENT 0.75 Ampere
INPUT VOLTAGE 12 VDC @ 750 mA
MAXIMUM CHARGE RATE 7.50 Ampere
RECHARGE TIME 8-12 hours
WARRANTY 5 year manufacturer's warranty – Go to www.h-d.com/warranty for full details
SOLD IN UNIT Each
IN THE BOX Quick-disconnect 7.5 Amp fused Battery Charging Harness with ring terminals and a 7.5 Amp fused alligator clip charging harness
