Cold starting problem
Old Nov 12, 2017 | 03:06 PM
Igoinxs's Avatar
Igoinxs
2nd Gear
Default Cold starting problem
Anyone having trouble starting their M8 in cold weather? Went on a toy drive run this morning and it was 20* when we left. My 17 RGS did not want to start. I had plenty of power to the starter, but the engine would not fire. After several minutes of trying the bike did eventually start. Anyone else having this problem?
Old Nov 12, 2017 | 03:09 PM
FLTRI17's Avatar
FLTRI17
Did you cycle the ignition switch each time you tried to start it? Makes a difference.
Bob
Old Nov 12, 2017 | 04:02 PM
Igoinxs's Avatar
Igoinxs
2nd Gear
yes, I did.
Old Nov 12, 2018 | 10:39 AM
Vision's Avatar
Vision
No one else having this cold start issue on their M8’s? My 3018 RGS wasn’t exactly fast starting in the summer. Now that the weather is colder, it’s really difficult to start. Checked the voltage and it’s not dropping under 10 volts when attempting to start until after several attempts. It sits at like 12.4 volt when I just turn the ignition switch on. I also hear the occasional loud clank when attempting to start. Could the starter be gone? Or maybe and issue with the spark plugs?
Old Nov 12, 2018 | 10:51 AM
fairlydangerous1's Avatar
fairlydangerous1
12.4 sounds low for a good battery. I would think it should be in low 13's when not in use.
Old Nov 12, 2018 | 12:27 PM
Erilflynn's Avatar
Erilflynn
Bob
I guess I'm simple. By cycling the ignition do you mean turn the kill/ignition to off then restart the process?
Old Nov 12, 2018 | 01:13 PM
KrustyKush's Avatar
KrustyKush
12.4v at rest is probably about 50% discharged. A fully charged batt at rest will be around 12.7v. Sometimes a good battery will show slightly above 13v immediately after a charge to full but as it sits for a couple of hours disconnected it will drop into the high 12s.
Old Nov 12, 2018 | 02:28 PM
Oz Dan's Avatar
Oz Dan
Do you have any mods?
I had an issue starting my bike cold at one point of time......was due to the wrong startup map being loaded into the ECU......the dyno guy loaded the power cam map rather than the Torque map. Fixed as soon as the right map was uploaded.
Old Nov 12, 2018 | 02:30 PM
smitty901's Avatar
smitty901
When starting at 20 degrees the bike has a tendency to flood it self. If it does roll the throttle all the way open hold and start it will start. Yes I start mine often in those temps.
Old Nov 12, 2018 | 03:59 PM
Vision's Avatar
Vision
Thanks guys. I will have the dealer check the battery again this week. Decided to take the bike out today and the bike Sumped on me. Smh. Always something.
DRated
May 14, 2018 03:05 PM
LQQK_OUT
Jun 2, 2015 10:31 AM
MJHJEA
EVO
Sep 15, 2014 06:46 PM
stbob07
Sep 11, 2012 09:16 PM
captjon37
Apr 10, 2010 04:48 AM
