Fixed the clutch switch issue.
Old Apr 11, 2018 | 03:57 PM
  #31
mjwebb's Avatar
mjwebb
Originally Posted by SpringerRider
A guy behind me heard me talking about it at the service desk and asked why he was not notified and they said, you have to ask.
yup, just like on the IT World I work in, it ain't a problem unless a trouble ticket is called in, created and assigned..gotta' follow protocol
Old Apr 11, 2018 | 04:29 PM
  #32
billbrummett's Avatar
billbrummett
Default paid? paid?
my M8 is in warranty, haven't paid for anything yet, and won't until July, 2019
Old Apr 12, 2018 | 11:58 PM
  #33
SomeOld Biker's Avatar
SomeOld Biker
Never had a problem with my clutch switch but put a little Tri-Flow lube on the button anyway. Thanks for the heads up!
Old Apr 21, 2018 | 10:48 AM
  #34
Heatwave's Avatar
Heatwave
Member
I did the WD 40 thing and it fixed it for a while. Then it came back and I couldn't get it working again. Told HD and as it turns out, there is a TSB about it.
They replaced the entire clutch caliper and lever. A guy behind me heard me talking about it at the service desk and asked why he was not notified and they said, you have to ask.
Anybody have a copy of this clutch TSB they can post up?
Old May 19, 2018 | 09:55 PM
  #35
tommy1727's Avatar
tommy1727
I could use a copy of that service bulletin as well. I have a bike I’m doing some work on for a friend and his has the same issue. Dealer had allegedly replaced the switch housing, but told him it was a wiring problem in the handlebars-which had been changed. He decided to change bars yet again and since I’m pulling all the harnesses and transferring to the new bars, I told him I’d check all the wiring out. Well, I tested all the harnesses and they are all good. So, I took that switch apart and it’s definitely not replaceable without the entire left bar switch assembly. Every switch function on that entire pack is relayed down the bars with 4 wires. Ground, hot, can high and can low. In this case, it’s not really Harley trying to get over on anyone by forcing them to replace the entire switch pack, it’s just a necessity of the systems design requirements. The clutch switch itself is a micro switch and has a very tiny on/off engagement point. Certainly, the quality might be better, but all the other switches in that assembly seem to be robust, as I have not heard of any major issues with loss of function on those. I’m guessing it’s an issue of interfacing the clutch lever with the switch button due to the short movement of the micro switch. Anyway, I stretched out the spring under the button, I’m hoping that will fix it, but if there is a new and improved switch I’ll tell him to go back to the Moco and bitch until they replace it. Although he might have already been reported for altering the bikes handlebars, subsequently voiding his warranty.
Old May 19, 2018 | 11:32 PM
  #36
XWFONinja's Avatar
XWFONinja
I had same issue on my 17 RK SP, sometimes would work fine, other times wouldn't work fine. Usually related to washing and raining. Finally decided to take apart to see if it was something I could fix. Didn't want to deal with the drop, wait dealer dance thing.
Spraying a lubricant isn't gonna necessarily fix the problem as I found out later when disassembling the switch. There is a silicone tab cover that wasn't mounted onto the micro-switch well. Removed, cleaned, stretched out spring as mentioned above and reassembled. So far, no problems. We'll see the next time I get rained on.
As mentioned, the reason this switch is so expensive is it's all one unit on a hinge in order to swing around handlebar. Note: the primary benefit to lubing this switch externally is to facilitate the barrel return operation, but if the barrel tab isn't engaging the micro switch properly via the silicone tab, it's mute.
Old May 1, 2020 | 09:25 AM
  #37
Sandusa's Avatar
Sandusa
Stage I
Have same issue but I am reluctant to try the famous WD40 next to sensitive electronic...
Old May 1, 2020 | 10:14 AM
  #38
OldMike's Avatar
OldMike
I wouldn't use that smelly crap on my bike either.
Amazon Amazon
Old Nov 10, 2020 | 08:17 AM
  #39
chmcgee's Avatar
chmcgee
6th Gear
Thumbs up Fix it yourself clutch switch button.
I was able to take the cap off the clutch switch button and stretch the spring about a half inch. Taking my time it took less than an hour and now works.
onebad2
Oct 3, 2013 08:58 PM
JakesDad1
Nov 26, 2010 01:56 PM
labou1
The General Motorcycle Forum
Feb 18, 2009 06:15 PM
CrimsonThunder
Aug 18, 2008 09:45 PM
Wally
Feb 19, 2008 12:28 PM
