Is there anything I need to know about switching from a chain driven cam to a gear driven cam on the M8? ie pinion run out, gear noise etc. I'm thinking about a S&S 465G.
Thanks.
Typical gear drive needs less than .003" total indicated runout, .000 to .001" is preferred- typical late model pressed together crank from HD has two to three times that runout- factory spec states up to .012" ( 4 times acceptable) is within spec.
Darkhorse or S&S flywheel would be the choice if gear drive was preferred.
Or use the hydro chain setup, and be happy...
Are you saying the stock HD is too far from spec to benefit ?
Or that it will improve it because it's out of spec ?
Cheers man.
Cheers man.
He's saying you need to check it.
Personally I don't think there's any real benefit to gear driven cams in the M8 despite the grief I'll get for saying it. Too much senseless fretting about old issues with tensioner shoes that are not an issue any more, and haven't been for years. You could also introduce new issues with the oil pump
Personally I don't think there's any real benefit to gear driven cams in the M8 despite the grief I'll get for saying it. Too much fretting about old issues with tensioner shoes that are not an issue any more, and haven't been for years.
My understanding is that your timing is more precise with a gear drive , whether that's true I'm not 100% on it's what I've been told , no vehicle I've had has used one, but for me the sound is cool from a gear drive..
If a gear driven cam is producing excessive whine, tolerances are slightly off or both gears are very new and haven't worn to each other.
I think a lot of twin cam guys forget that the camshaft was gear driven for many years.
I don't hear gear whine in the single counter balanced M8 used in the touring bikes but I find it very pronounced in the M8 Softails which have two counter balancers. With time, I am sure the gears will wear to each other and the whining will subside.
Since they are driving counter balancers with gears, it seems like they would have driven the cam with gears as well.
Timing is more precise with gears, but isn't a noticeable difference that can be felt in this application. On an automobile engine making hundreds of horsepower, it makes more of a difference.
It's a shaft- if the runout is 0, the pinion shaft turns in a circular motion. If there is .003" TIR, then it turns in a tiny oval. If the TIR is .012", then the oval is more pronounced. Think bent shaft. As the bend moves toward the cam, clearances are reduced towards binding, and "gear whine". As the bend goes away from the cam, clearances increase; then, the force of the valve springs can push the cam forward or backwards, thus the "clacking" sound. HD went away from the gears, and their required tighter tolerances, to speed up production, and reduce sound- DOT has noise restrictions, and HD had already replaced the chain with a belt to reduce sound levels.
Gear drive requires a "hand fit" style of assembly, and tight tolerance components- chain drive allows for much wider tolerances, and is faster to assemble- good for production pieces, and once they figured out the hydro chain setup, very durable.
